cancel
Job type :
Zip Code :
community forums
comments
Wood Preservative
You need to apply a coating of a wood preservative to all the wooden furniture in your home. Apart from its protective properties, a wood preservative also helps in bringing out the beauty of the natural wooden grain. This can make even an ordinary piece of furniture look classy.
By applying a wood preservative you can enhance the service life of your wooden furniture and storage cabinets.
Why Should you Apply a Wood Preservative?
An even coat of wood preservative seeps into the micro holes in the wood structure and prevents moisture from entering into the heart of the wood. This restricts the growth of fungus in the internal environment of your home. If you do not use a wood preservative, your precious furniture could be susceptible to attack from termites and from the changes in the weather conditions.
A wood preservative can be applied by either brushing or spraying it on the wooden surface. It is recommended that you apply two coats of wood preservative on any surface for best results.
member comments
Related Articles
Preservative
A preservative is any material, usually chemical, applied to wood to extend the life of... read more
Putting the Finishing Touches on Your Wood
The helpful list in this article will help you select the right type of finish... read more
Clear FinishesClear Finishes
This wood finish section provides useful information on how to apply clear finishes to your... read more
articles we like
Comprehensive Health Care
Comprehensive health care in the United States is among the best in the world. There... read more
Ribbon
In construction terms a ribbon refers to a board or lengths of board which are... read more
You Can Get Your Cat to Use a Scratching PostYou Can Get Your Cat to Use a Scratching Post
Clawing comes naturally to cats for a number of reasons: it helps them mark territory,... read more
sponsored articles of the day
diy centers
