cancel
Job type :
Zip Code :
community forums
comments
Wind Patterns: Placing Windows for Cross Ventilation
Utilizing wind patterns to create cross ventilation depends on the placement of windows in your home.
Step 1 - What is Cross Ventilation?
Cross ventilation occurs when air flows through one window in your home and out another window. In order to take advantage of wind patterns the windows should be on opposite sides of the house.
Step 2 - Wind Patterns and Cross Ventilation
Wind patterns are a source of air pressure by determining which side of the house is receiving the high air pressure you can achieve cross ventilation. By opening the window with the high air pressure and opening another window across from it you allow the low pressure to escape. This causes a cross ventilation of air.
Step 3 - Optimal Use of Wind Patterns for Cross Ventilation
By not completely opening the window with the high pressure and fully opening the opposite window the force of the air flow is more effective.
Step 4 - Knowing the Predominant Wind Patterns in Your Area
When building a new home you can take note of the wind patterns and place your windows where you can create cross ventilation.
member comments
Related Articles
Selecting Replacement Windows and the Contractor: What You Need to Know
Read this article for more information on what to consider when selecting new windows for... read more
How to Install Vinyl Sided Window
Step-by-step guide to installing vinyl replacement windows... read more
Installing Glass Windows Step-By-Step
Replacing a glass window is a very simple process that becomes easier after you do... read more
articles we like
Cleaning Mildew in Your Home
Cleaning mildew is essential for more than just aesthetic reasons. Mildew is a term that... read more
Site Work
Site work is a term used to describe any work done when preparing a site... read more
Get a Head Start on Your New Year's ResolutionGet a Head Start on Your New Year's Resolution
The following article provides information on how to make your weight-loss resolution a successful undertaking... read more
sponsored articles of the day
diy centers
