cancel
Job type :
Zip Code :
community forums
comments
Water Conservation: Save Your Bill And The Enviornment
Many areas across the US have received a water quota that restricts the amount of water that the area can use. Conserve water in your own home in order to maximize the use of this resource and prevent extra costs of using too much.
Kitchen
In the kitchen, you use water for drinking, cleaning dishes, washing hands and much more. To conserve the amount of water you use, install a faucet that uses low water pressure. These are relatively inexpensive and can cut back on the amount of water that you don't even notice is wasted.
Consider a specialty dishwasher that uses less water than traditional washers. Like the controlled pressure faucet, this can have a drastic effect on your home's water usage, and it comes at a price only slightly higher than a regular washer.
Finally, store drinking water in a pitcher in the refrigerator. This will prevent you from running the tap while you wait for cold water to come out.
Bathroom
In the bathroom, shut off the water while you brush your teeth, shave and wash your face. Make showers only as long as you need to get clean, and avoid baths, which waste gallons of water.
A low pressure faucet would be ideal for a bathroom as well as a kitchen. Also consider a more efficient toilet. They use less water, and some models even allow you to choose between a half-flush and a full flush to minimize water use. Another benefit to buying one of these toilets is in case the handle on your current toilet sticks so that the water unnecessarily runs.
member comments
Related Articles
Sports the Green Way
With an ever-growing awareness of our environment and the impact our activities have on the... read more
Going Green: The Wonders Water Bottles Can Do
If you are trying to go green with your active, on the go lifestyle, there... read more
Utility Trucks And The Environment
It is a well know fact that SUV's are responsible for emitting the highest ... read more
articles we like
Window Security Film
Window security film is a heavy plastic film that is applied to windows in order... read more
Many Options For Bay Window Curtains
Bay window curtains give privacy to bay windows, which are often the focal point of... read more
Learn how to escape crippling debt problemsLearn how to escape crippling debt problems
If you've faced layoffs, then you know all too well how easy it is to... read more
sponsored articles of the day
diy centers
