cancel
Job type :
Zip Code :
community forums
comments
Tung Oil
Tung oil is a special kind of oil gathered from the seeds of a Tung tree. It is very good at finishing wood because it is water resistant and able to protect the wood from small scratches. Tung oil can be picked up at some hardware stores.
• Step 1: Make sure the wood you will be using it on is clean and dry.
• Step 2: Apply a large amount of Tung oil to a cloth and rub it into the wood. Continue rubbing in the oil until it can't soak any more up.
• Step 3: Use a clean cloth to rub the wood dry.
• Step 4: Allow the wood to dry for 12-24 hours.
• Step 5: Rub "0000" steel wool on the wood once it has dried and do one or two more coats with the same process.
Repairing Small Holes With Tung Oil
If you scratch the wood there is a chance that it can be repaired with more Tung oil. Simply repeat the process on more time on the side of the wood with the scratch. Once you have finished the scratch should blend in and feel the same as the rest of the board.
member comments
Related Articles
Drying Oil
A drying oil is used in oil paints and varnishes and causes it to get... read more
Putting the Finishing Touches on Your Wood
The helpful list in this article will help you select the right type of finish... read more
Old-Fashioned Furniture Refinishing
If you would like to learn how to refinish your furniture using traditional methods then... read more
articles we like
Dry Cleaning
The process of dry cleaning, just as the name implies, is cleaning garments and textiles... read more
Nominal Size
The nominal size is a term used for lumber that is not dressed, or finished... read more
Considering an Online University? Make Sure it Stands OutConsidering an Online University? Make Sure it Stands Out
There are many universities offering degrees and certificates online, but very few offer high-quality, low-cost... read more
sponsored articles of the day
diy centers
