cancel
Job type :
Zip Code :
community forums
comments
Transform Your Brick Fireplace: Remodeling with Paint
The prospect of completing a brick fireplace remodel by removing the existing bricks is not exactly appealing. However, there are alternatives to replacing the brick and one is to use specially formulated paint just for brick. You can paint your fireplace in two easy steps as shown below:
Step 1-Clean the Existing Brick
First, you will need to clean the existing brick with a wire brush.  This will remove any loose mortar and dirt from the brick. Cleaning the brick ensures that the paint will bond with the surface of the brick.
Step 2-Applying the Paint
After you’ve finished the cleaning and the brick has dried, you can begin to apply the paint.  It’s best to apply this paint with a large brush (4” or larger) making sure to work the paint in to all the mortar joints.  At least two coats of paint should be applied but more may be required depending on the condition of the brick. You can find the paint very easily at your local hardware store.
member comments
Related Articles
Heating Wood Stoves
Heating wood stoves provide an alternative to fireplaces and other heating options. Similar in design... read more
Chimney FiresChimney Fires
What you should know about chimney fires, how to avoid them, and what to do... read more
Integrated Wood Energy Systems for Sustainable Housing
This paper discusses environmentally sustainable housing principles and illustrates their application with three built projects... read more
articles we like
Canning Vegetables
Canning vegetables is a simple way of storing freshness and taste. If you are able... read more
Nominal Size
The nominal size is a term used for lumber that is not dressed, or finished... read more
Dude! Ready for Something Different? Try a Dude Ranch
Does shopping in New York or L.A. leave you with a "been there, done that"... read more
sponsored articles of the day
diy centers
