cancel
Job type :
Zip Code :
community forums
comments
Tack Rag
A tack rag is made from a cotton or cheese cloth rag that has been soaked with a thinned varnish. It is used to help pick up small dust particles before you begin applying varnish, stain, sealant, or polish. If you don't use a tack rag it is possible that the dust particles will be sealed underneath the surface and causes the polishes to become dim or not as glossy.
• Step 1: Dip a rag made from cotton or cheese cloth into water and squeezes it dry.
• Step 2: Sprinkle a little bit of turpentine onto the rag, but not too much.
• Step 3: Sprinkle on three tablespoons varnish over the surface of the rag and work the material to mix them together.
• Step 4: Wipe the tack rag over the surface of your project and let dry before you begin to apply the sealant.
Disposing a Tack Rag
As with any material that has a varnish or turpentine on it, you must take special precautions while disposing it. Varnish and turpentine are capable of spontaneous combustion when they are left on a crumpled rag or in the sunlight. Rinse the tack rag with water and lay the rag flat on the ground or a table while it dries.
member comments
Related Articles
How to Properly Finish a Band Saw BoxHow to Properly Finish a Band Saw Box
This section provides a step-by-step approach to finishing a band saw box... read more
Applying Spar Varnish on Outdoor Furniture
Outdoor wooden furniture takes quite a lot of abuse so to keep the elements at... read more
Clear FinishesClear Finishes
This wood finish section provides useful information on how to apply clear finishes to your... read more
articles we like
Canning Vegetables
Canning vegetables is a simple way of storing freshness and taste. If you are able... read more
Structural Timbers
Structural timbers are wood pieces larger than 4X6, used in framing and structural construction. Structural... read more
Top Five Reasons for a Vegas VacationTop Five Reasons for a Vegas Vacation
Las Vegas, Nevada is one of America's most visited cities for a reason. Whether you... read more
sponsored articles of the day
diy centers
