cancel
Job type :
Zip Code :
community forums
comments
Support Column
If you are thinking of redoing your basement, you are probably wondering how to hide a support column. The column is used to hold your home in place, so it cannot be removed or moved around.
The best way is to work around it, here are a few ideas to hide your support column.
  • Build a large box around the pole and use crown molding to make it look decorative.
  • Move a large piece of furniture like a couch or entertainment center right next to the pole so that it is not as noticeable and not in anyone's walking path.
  • Build a shelf around it.
  • Make a seating arrangement that wraps around the pole.
  • Hide the column behind large pieces of furniture.
Painting a Support Column
Sometimes a support column will look much nicer if it has a fresh coat of paint. Since it is metal, the column must first be primed before it can be painted. Pick out a neutral color that will match the floor or walls, this will make it blend in. Spray paint is best for this project because it won't leave behind stroke marks and will only require one or two coats.
member comments
Related Articles
Basement Remodeling Contractors Turn Your Basement From Drab to Fab!Basement Remodeling Contractors Turn Your Basement From Drab to Fab!
When you hear someone say the words "basement renovation," it often evokes images of enjoying... read more
Support Columns
Support columns are used to help raise floor joists so that floors don't sag. If... read more
Hiding Unsightly Support Columns: Six Ideas
Basements and other rooms with large open spaces often require hiding unsightly support columns... read more
articles we like
Creating Your Own Bay Window Treatments
Bay window treatments finish the look of a bay window. There are many options for... read more
Canning Vegetables
Canning vegetables is a simple way of storing freshness and taste. If you are able... read more
Want Job Security? Protect Your Future With a Degree in Criminal JusticeWant Job Security? Protect Your Future With a Degree in Criminal Justice
If you've always wanted to be the one to take down the bad guys, there's... read more
sponsored articles of the day
diy centers
