by Alden Smith
There are often times when it is just about impossible to remodel a bathroom and make it larger in the process. Although there are solutions, it often involves major cost to the home owner. Such things as moving a load bearing wall or having to deal with an older, possibly faulty plumbing system takes a huge bite out of the budget. Because remodeling a bathroom is the most expensive room in the house, you often need to make do with what you have.
Bathrooms, especially in older homes, often did not use visual cues and plans to make it look larger than it actually is. They were often looked upon as utilitarian, and often the focus was on "making it cuter." Designs and uses of the bathroom today have changed. People want a room that they feel relaxed in and where they can enjoy themselves. Here, we will look at ways to make a small bathroom look larger than it actually is.The Illusion Of Space
Many older bathrooms are carpeted. While this is nice when you get out of the shower or are in bare feet, it does little to make a room look larger. Color schemes today can be used to make a bathroom look larger than it actually is. The use of soft pale colors on floor and walls make a room appear larger than it is. The same goes for bathroom fixtures. The key here is to use soft, pale colors, and then add decorative touches in strong, bold colors to give the appearance of space. Consider painting a large stencil on the largest wall. This helps to give the illusion of space, especially if reflected in a mirror. Consider putting up a picture in the bathroom that is a scene of an outdoor garden or beach. This gives the illusion of looking out a window and seeing open space. Bold colors in towels help a great deal. One trick I have seen is the use of a black vanity with white sink. Accessories in the bath should also be strong in color. Try to avoid rich, dark woods and flooring.
The Use Of Glass
One thing often overlooked is the use of glass to give the illusion of space. Do away with the frosted shower doors and shower curtains. Opt for the new seamless glass doors for the shower, and you will be amazed at how much larger a room will seem. Glass is very reflective, and when used in such things as decorative shelves, really improves the look. Take advantage of the old trick of putting mirrors on opposite walls so that they reflect one another, giving the illusion of space that really isn't there.
Although many people use their vanity cabinets for storage, consider finding an alternative for storage of cleaning supplies and put in one of the new glass pedestal sinks. You gain space both in length and underneath, but also add the illusion of extra space, even though you gain little.
The Use Of Natural Light
Light always gives the illusion of space. If structurally possible, consider putting a larger window in the bathroom. Older baths almost always have a very small window. Opening this up helps give the illusion of space. If possible, put a skylight in your bathroom to provide more natural light.
The Use Of Artificial Light
Lighting always helps make a room look larger, and if you add recessed lighting, you can point this light at specific areas, such as the vanity. Fluorescent lights in a bathroom tend to make a ceiling lower than it actually is, although it provides good lighting. A contractor researched online warns people to not use too much lighting of this type in the bathroom. Excessive focused lighting can quickly heat up a small space.
The Use of Embellishments
Designers researched warn against anything in a small bathroom that sticks out and causes a "stop place" for the eye when entering a small bathroom. Hanging racks, wall shelves and other such non-essential items in a bath can go, unless they serve a specific need. Another designer trick is to use crown molding in the bath. If crown molding is just too much for you, consider painting a lattice around the wall at ceiling level. Be careful here - try to insure that it is scaled for the size of the room.
A small bathroom does not have to be a depressing space. Using simple designer tricks that don't require a huge cash outlay goes a long way in making your bathroom look larger than it actually is. Just use your creative powers and imagination, and you will have a bathroom that looks large, even if it isn't.
Questions of a Do It Yourself nature should be submitted to our
All the ideas for remodeling a bathroom are great, but I have a really, really,really small bathroom - approximately 7 ft X 5 ft. wide. I want to take the tub out and put in a shower.
Whoever lived here before, put the pedestal sink at the entrance on the left side as you walk in (door opens out into the hallway) and the commode on the opposite wall next to the tub . So there is hardly any space to stand when you get out of the tub!
Help! I need ideas to make this tiny, tiny bathroom feel bigger. Knocking out walls is out of the question. (newly remodeled kitchen on one side and a very small bedroom on the other side - house is 745 sq. ft.) My husband and I are in our sixties so we do not want or need a tub - shower is much safer for us now.
Anyone have any remodeling ideas? Any ideas will be welcomed!
