cancel
Job type :
Zip Code :
community forums
comments
Slate
Slate is a type of stone which is fine grained and highly resistant to rain, snow and sun.
What is Slate Used for?
Due to its nature and its resistance to varying types of weather, slate is often used for outside construction. The most common use of slate is as flagstone in the construction of garden paths and terraces and as an attractive patio cover. Generally, slate will be installed directly in the dirt. The process involves first, removing sections of grass to provide a level dirt surface followed by placing the slate down.
Sometimes sand will be used as filler to help anchor the stones in place providing a more solid surface. This will help to prevent future movement. Sand functions well for holding slate in place due to its small grain characteristics. It will fill in uneven spots and will compact over time providing a solid level surface for the stone to sit on top of. Concrete is also used when installing slate under certain circumstances.
member comments
Related Articles
Slate Patio Design Ideas
Due to its fine-grained texture, smooth finish, and durability, slate patio has become a popular... read more
Sublime Stone: Elegant Hardscape Features
This article highlights easy ways you can enrich the look and feel of your garden... read more
What To Know Before Buying Slate Shingles
Slate shingles are a great shingle choice for those who want to have a beautiful... read more
articles we like
Removing Window Tint From Your Car
If you want to remove window tint first consider the fact that most window tinting... read more
Nominal Size
The nominal size is a term used for lumber that is not dressed, or finished... read more
5 Nutrition Musts for Pregnant and Would-be Moms5 Nutrition Musts for Pregnant and Would-be Moms
By getting the proper balance of vitamins and minerals while pregnant, a mother can help... read more
sponsored articles of the day
diy centers
