cancel
Find Qualified
Local Contractors
Select Service:
Enter Zip:
community forums
Selecting the Right Hammer for the Job
comments
Hammer Safety Tips:
  •  Do not strike a hardened steel surface, concrete or stone with a steel claw hammer. Metal chips can result in injury to the user or any bystanders.
  •  Never use a hammer with a loose, cracked or broken handle—replace the handle.
  •  Never use a hammer with a chipped, cracked or mushroomed face.
  •  Discard hammers with cracked claws or eye sections.
  •  Do not use the hammer handle for striking, and never use it as a pry bar—this could cause the handle to split.
  •  Always strike the surface squarely—avoid making glancing blows.
  •  Always wear safety goggles when hammering any object.
  •  Never strike a hammer with or against another hammer.
  •  Always use a hammer of the right size and weight for the job.
    Nail Hammer
  •  Used for general carpentry, household chores and nail pulling.
  •  Should be used only with non-hardened, common or finishing nails.
  •  Curved claw offers leverage in removing nails and can also cradle a 2x4.
  •  Choose 16 or 20 oz. weights for general carpentry; choose 7, 10 and 13 oz. weights for fine cabinetry or light-duty driving.
  •  Available with smooth or waffled (serrated) faces. Milled face is for finishing jobs while waffled face provides more control when hammering large nails into lumber. Some claw hammers feature a side notch on the head for easier pulling of small nails and fasteners.
    Framing Hammer
  •  Also known as a Rip Hammer
  •  Used mainly by professionals for ripping apart wooden components and demolition work.
  •  Choose weights from 20 to 32 oz. for framing and ripping.
  •  Available with milled or waffled faces to grip the nail head and reduce the effect of glancing blows and flying nails.
    Finishing Hammer
  •  Used for general carpentry, finishing and cabinet making.
  •  Head size generally between 7 oz. and 16 oz.
  •  Smooth striking face so errant strikes don’t leave marks on the wood.
    Tack Hammer
  •  Used for furniture upholstery and to drive small nails and tacks.
  •  Round face on one end is designed to pick up nails and tacks, while a narrow, square head on the other end is used to drive them.
  •  Features a magnetic face opposite either a driving face or a claw.
  • Sledgehammer
  •  Used for jobs where great force is required such as breaking up concrete or driving heavy spikes.
  •  Feature long handles from 14” to 36” and heavy heads weighing from 2 lbs. to 20 lbs.
  •  Double-face sledgehammers feature two identical faces.
  •  Single-face sledgehammers have one flat face for striking and one wedge-shaped face for splitting wood.
    Ball Peen (Ball Pein) Hammer
  •  Used with cold chisels for riveting, center punching and forming unhardened metal work.
  •  Striking face diameter should be about 3/8” larger than the diameter of the head of the object being struck.
  •  Designed with a regular striking face on one end and a rounded or half ball on the other end instead of a claw.
  • Sizes range from 2 oz. to 48 oz. with 12 and 16 oz. the most popular.
  •  Variations include a cross-peen hammer (with horizontal wedge-shaped face) and a straight-peen hammer (with vertical wedge-shaped face).
    Hand Drilling Hammer
  •  Has short handles and is used for pounding hardened nails into concrete or for using with tools that drive nails and pins into concrete or brick.
  •  Only hammer to use with star drills, masonry nails, steel chisels and nail pullers.
  •  Weighs between 2 lbs. and 4 lbs.
  •  Larger striking surface, generous bevel and special heat-treating minimize chance of chipping the striking face
  • Soft-Face Hammer
  •  Used for assembling furniture, setting dowels and wood projects that requires non-marring blows.
  •  Available in weights ranging from 4 oz. to 22 oz.
  •  Feature replaceable heads, typically one soft and one hard
  • Bricklayer's Hammer
  •  Used for setting or splitting bricks, and chipping mortar from bricks.
  •  Features a curved, chisel-like pick and a small, square striking surface.
    Shingler's Hammer
  •  Drives roofing nails, assures proper shingle spacing, trims composition and fiberglass shingles.
  •  Typically includes slotted, retractable cutting blade
    Drywall Hammer
  •  Used to score, sheet and set nails for drywall work.
  • Features a scored head and a notched blade instead of a claw.
  •  Notch in the blade is used to remove exposed nails.
    Mallet
  •  Has rubber, plastic, wooden or rawhide head.
  •  Used to drive chisels or hammer joints together.
  •  Sizes are specified in head weight or diameter with the exception of wooden mallets, which are specified by head diameter only.
  •  Comes in variety of shapes and sizes for specific tasks.
  •  Carpentry mallet features angled head to reduce fatigue; shop mallet with octagonal head is used for flat strikes; rawhide mallet is used in furniture assembly.
    Courtesy of NRHA.org
    member comments
    Related Articles
    Road Hammers
    Anyone who will be doing work drilling concrete or other masonry really must invest in... read more
    Selecting the Right Drill for the Job
    This article highlights the characteristics of 5 different power drills to help you decide which... read more
    How to Install Ceiling Tiles
    How to Install Ceiling Tiles... read more
    articles we like
    Granite Countertop Colors
    Black is the most common granite countertop color. This has led to the perception that... read more
    Vinyl Windows Price
    Vinyl windows price per window is more attractive now than ever before. The price will... read more
    The Secret to Vacation SavingsThe Secret to Vacation Savings
    Book your winter vacation now for big savings... read more
    sponsored articles of the day
    diy centers
