cancel
Looking for a car?
community forums
comments
Reprogramming the Door Lock Remote for Your Car
If you have a door lock remote for your vehicle, the programming may get out of synch or you may need a replacement. In these cases, reprogramming the remote is necessary.
Here are the steps to do so with a Dodge car; these steps vary slightly by manufacturer:
Step 1 – Check the Battery
Sometimes your programming problem happens as the result of a low battery. Be sure to put a fresh battery in the remote before you reprogram, or you’ll end up with the same problem.
Step 2 – Locate Data Link Connector
Under the driver’s side dash, there is a 16 pin connector. This is located near where the right knee is when driving. Use a wire to ground pin 1 by connecting the wire to pin 4. Pin 4 is a ground pin, so when pin 1 is connected, the system is ready to reprogram.
Step 2 – Insert Key
Put the key in the ignition and turn to “ACC” then back to off. Doors lock and unlock signaling readiness to program.
Step 3 – Push a Button
Choose any button on the remote and push it. If you have a second fob, push a button on that fob as well, within one minute. If you only have one fob, push the button several times. Doors lock and unlock to signal they are done.
Step 4 – Remove Wire
Remove ground wire, and the reprogramming is finished.
member comments
Related Articles
Keeping Your Car Running Smoothly
Keeping Your Car Running Smoothly... read more
Buying a Used CarBuying a Used Car
Useful information on buying a used car... read more
What to Do When Professional Auto Repair Doesn't Solve the ProblemWhat to Do When Professional Auto Repair Doesn't Solve the Problem
Answers to questions about mechanics... read more
articles we like
Screed
A screed is a flat, straight tool used for the purpose of leveling and smoothing... read more
Postpartum Depression
Postpartum depression can bring on a wide range of emotions fill the expectant mother, and... read more
Credit Repair is More Than a Right, It's Your ResponsibilityCredit Repair is More Than a Right, It's Your Responsibility
The majority of Americans have errors and other unverifiable information on their credit reports that... read more
sponsored articles of the day
diy centers
