cancel
Job type :
Zip Code :
community forums
comments
Replacing a Dryer Vent Hood
A dryer vent hood directs the hot air and lint from the dryer duct as it leaves the home. The hoods may become cracked or broken, and need to be replaced periodically.
Remove the Old Hood
Dryer vent hoods are generally connected to the exterior wall of the home. Check the old hood for the type of screw that was used in its installation, then use the appropriate screwdriver to remove the screws. The hood may still be attached to the wall of the home because of sealant or caulking used to cover any cracks. Use a utility knife to cut through the sealant and remove the hood.
Detach from Dryer Duct
The hood may be attached to the dryer duct inside the wall with a clamp or metal duct tape. Remove the clamp or tape and free the old hood from the interior ductwork.
Tape or Clamp New Hood
Inside the wall, attach the new duct hood to the interior dryer duct with the clamp or tape recommended by the manufacturer.
Attach Hood to Exterior Wall
Using screws (usually provided in the duct hood kit), attach the new hood to the exterior wall where you removed the old one. Use a silicone caulk/sealant around the joint to close any gaps and stop any air escape.
member comments
Related Articles
Save Warm Air: Vented Dryer Dehumidifier
A vented dryer dehumidifier is a standard dryer with a vent, as opposed to a... read more
Venting Your Clothes Dryer: A Fast but Vital Job
Advice on properly venting your clothes dryer... read more
Are Dryer Vent Kits a Worthy Purchase?
If you are installing or replacing a dryer vent, a dryer vent kit could be... read more
articles we like
Office Chair
The office chair, or desk chair is a familiar and constantly used part of the... read more
Customize Your Window Treatments
Custom window treatments let you coordinate the style, pattern and color of your window treatments... read more
How to live healthier as you age How to live healthier as you age
For a long time, doctors and researchers have touted the health benefits of red wine... read more
sponsored articles of the day
diy centers
