By Brian Simkins
Armed with the knowledge and confidence to tackle your own toilet problems, you can put your plumber's phone number back in the rolodex the next time you just need to replace a common part. The toilet is one of the simplest mechanical items in your home, and with a basic understanding of how it works, you can fix it yourself.What you'll need:
- Adjustable Wrench: This will allow you to loosen and tighten almost every part on your toilet.
- Pliers: A pair of pliers may be required for squeezing closed clips for a few kinds of flapper valves.
- Screwdriver: A screwdriver will most likely be necessary when installing the bolts for a new toilet seat.
What follows is a list of common problems, how to identify them, and a solution. Being able to properly diagnose a problem will get you well on your way to making the repair.
The Flush Lever: This is the part of the toilet that gets the most abuse. The handle that activates the flushing action of the toilet is probably the most commonly broken moving part of the toilet. The lever is a rod that extends from the handle to a chain that activates the flapper valve.
There are several things that can go wrong with these handles. The rod used to be made of steel or brass. Of course, when steel sits in a wet place like your toilet tank over a period of years, it begins to deteriorate. Eventually the rod just corrodes to the point that it breaks. Not to long ago, manufacturers started making the rods out of plastic, as it's cheaper and doesn't rust. It does break, however. Whether you find plastic, steel or brass inside your tank, it's pretty common to need to replace your flush lever and handle.
The handle is generally held in place by a nut that is secured against the wall of the tank. It should be located at the place where the handle comes in from outside of the tank. This nut can be loosened with your adjustable wrench. Once the nut has been removed, the handle can be slid right out through the hole in the tank wall. Slide the new one in and tighten the nut back into place.
The Flapper Valve: The flapper valve is the mechanism inside your toilet tank that controls the flush. When you push on the handle, the lever lifts a chain that in turn, lifts the flapper valve. The valve covers an opening in the bottom of the tank that allows the water to flow down into the bowl and creates the flushing action.
This valve is usually made of rubber, and can become hard and brittle over time. When this happens, it doesn't seal correctly over the opening at the bottom of the tank and water seeps down into the bowl. The problem is usually identified by your toilet running non-stop. The tank just keep trying to fill itself unsuccessfully because all of the water is leaking around the edge of the valve.
In order to change the valve, you first need to empty the tank of water so that you can work. Find the shut off valve that is located on the water line that supplies your toilet. Turn it off, and then flush the toilet one time. The tank should empty as normal with the flush, but will not refill.
There are several different styles of flapper valves, and the best way to ensure that you get the right one is to remove it and take it with you to the store. Install the new one into the clips that held the old valve in place, and then turn the water supply back on. It should be as good as new.
The Float System: The float system in your toilet tank controls how much water comes into the tank. When you flush, all of the water in the tank rushes down into the bowl, leaving the tank empty. As the tank empties itself, a switch is activated by the float that falls with the water level. That switch opens a valve, which begins to refill the tank. As the tank refills with water, the float begins to rise, and when it reaches the appropriate level, shuts the valve off.
Like the problem with the flapper valve, a defective float switch will cause the toilet to sound like it is running constantly. The way to differentiate between the two problems is to take a look inside the tank. There should be a long hollow pipe standing next to the float mechanism. If the water level is so high that the excess is pouring down that overflow pipe, then your float switch isn't working. It means that your toilet is endlessly filling itself and the excess water is running down the overflow pipe and into the toilet bowl.
To replace the float system, drain the tank in the same way that we discussed above when changing the flapper valve. Once the tank is empty, you will find a large nut at the base of the float system. Loosen that nut and remove the entire float system. Keep in mind that, on some models, the flapper valve is integrated into the float system structure. If this is the case, then the float rod should be able to be removed by itself.
As with the flapper valve, there are several different styles available, and the best way to ensure that you get what you need is to take the old one with you to the store. The new one can be installed in the same way the old one came out. Make sure that you tighten the nut securely, but don't over tighten. The plastic that is used to make the float systems can crack fairly easily.
These are the most common problems that you will encounter inside your toilet tank. Take the time to identify the problem correctly, and you should have no problem replacing these parts. They are all easy to get to and do not require any special tools to get the job done right.
Questions of a Do It Yourself nature should be submitted to our
Dear Sir,
I've attempted to change my toilet flapper valve with a new one recently but after installing the new flapper valve,the toilet fails to flush.In need of your opinion to what might be the cause of this problems.Your valued opinion is much appreciated.
Thanks and regards
Zaidi(znrzai@yahoo.com.sg)
