cancel
Job type :
Zip Code :
community forums
comments
Selecting the Right Paving Materials
Paving materials are any material that is used to create a driveway, path or patio. There are a number of options available in paving materials. The right selection can have a big impact on a job. To make sure the right materials are picked, follow this process:
Step 1 – Consider the Job for Paving Materials
Before selecting paving materials, carefully define the scope of the job. Certain materials, such as concrete, are ideal for driveways and walkways. Bricks or cobblestone, for example, might look spectacular, but they are not always the best choice for drives.
Step 2 – Consider the Costs
Before making a choice among paving materials, do consider the costs. It can, for example, be much more economic to make a short path out of standard paver stones than concrete. The opposite may be true, however, for a large driveway.
Step 3 – Keep the Final Look in Mind
Do consider aesthetics when making a decision among different paving materials. Putting concrete down in an old fashion garden, for example, might take away from the final appearance. Cobblestones, however, could complete the picture perfectly.
Step 4 – Consider the Labor Involved
Paving materials, no matter the type, will require serious labor to install. Some jobs, however, are just bigger than others. If labor is a concern, make the final selection carefully. Stone, bricks and blocks, for example, can often be placed with a few simple steps. Concrete and asphalt will take more work.
member comments
Related Articles
DIY Block Paving
Block paving involves the installation of blocks, bricks or special paving stones to create a... read more
Tips for Paving an Asphalt Driveway
Here's what you can expect if you are planning to have an asphalt driveway installed... read more
Make a Statement With Brick PaversMake a Statement With Brick Pavers
This article shows how to make a statement with brick pavers... read more
articles we like
Marble Countertops
Marble countertops are made from highly polished hard crystalline rock. Marble is a metamorphic rock... read more
Casement Windows
Defined as a window that is connected to its frame by a series of hinges,... read more
How Health Savings Accounts Work
A month ago, Jenny Thomas checked into her local hospital to deliver her first child... read more
sponsored articles of the day
diy centers
