Having an outdoor electrical outlet can be a huge convenience, but they can be a safety concern, too. Here are a few tips to keep you and your home safe.
Water Hazards
When considering outdoor electrical outlets, remember to be sure they are not placed near water sources. Some homes have a water hose connection near an outlet, and if this is the case at your home, one option is to cover the outlet with a weatherproof box. Also, keep plug covers in the outlet for added safety.
Using Extension Cords
If you need to use extension cords outdoors, make sure the cords you have are listed for outdoor use. They need to be able to weather harsh conditions and be made specifically for outdoor use. It’s also important to make sure you aren’t overloading the circuit being used, especially if you’re using high-powered tools.
Proximities of Fuel
It’s good safety practice to make sure you don't store any gas-powered tools or gas cans near the electrical outlet. Something as simple as turning on a power tool near a container of fuel can cause a spark, and sparks can ignite a larger gas source.
Tool Storage
Always be sure to store outdoor electrical tools in a clean, dry place. A secure, weatherproof storage shed is ideal. If this isn’t available it’s best to store them indoors. This will keep the electrical components in the tools intact and help avoid issues with the outlet in the future.
Questions of a Do It Yourself nature should be submitted to our
