cancel
Job type :
Zip Code :
community forums
comments
Marble Tile Fireplace Cost Estimation
A marble tile fireplace is one of the most elegant designs for a fireplace that there is. Marble tile is not only beautiful but it is also extremely durable and extremely heat resistant.
How Much Will a Marble Tile Fireplace Cost?
A marble tile fireplace is an expensive investment. Marble is one of the most expensive natural stone flooring options. Determining the overall cost depends on several factors.
  • The number of marble tiles which are needed. This will depend on the size of the fireplace and how far out from the fireplace that you want to install the tile.
  • The cut size of the marble tiles. Larger cut size tiles are more expensive but add a smoother finish.
  • The depth of the marble tiles. Thicker tiles are more durable but they cost more.
  • The cost of grout and adhesive. If the marble tile will be installed on the fireplace then a heat resistant adhesive is necessary. The amount needed will depend on the size of the fireplace.
member comments
Related Articles
Wood Pellet Stoves: Tips and Tricks
Wood pellet stoves are stoves that burn compressed wood for heating residential spaces. Wood pellets... read more
Chimney FiresChimney Fires
What you should know about chimney fires, how to avoid them, and what to do... read more
Wood Stoves
Wood stoves are basically freestanding fireplaces that are used to generate indoor heat. Operating on... read more
articles we like
Dry Cleaning
The process of dry cleaning, just as the name implies, is cleaning garments and textiles... read more
Casement Windows
Defined as a window that is connected to its frame by a series of hinges,... read more
Reduce Expenses and Save up to $800 on Auto InsuranceReduce Expenses and Save up to $800 on Auto Insurance
Feel like your budget is stretched so thin you can no longer afford those little... read more
sponsored articles of the day
diy centers
