cancel
Job type :
Zip Code :
community forums
comments
Little-Known Secrets of Laminate Floor Installation
There are some aspects of laminate floor installation that aren't always obvious when the experts breeze through it on TV.
  1. It is NOT a one-person job! Even in a small room, a row is likely to consist of at least 2 or 3 sections of plank, and these short joints all need to be supported while the row is being locked into the previous row.
  2. Unless you are using high-end laminate, the tongue and groove system which holds the whole system together is made of fiberboard, which is essentially pressed cardboard.
  3. The small print on the package will say that each piece of laminate plank is good for 6 repositions.  This can sound like a lot, but if things aren’t coming together, you can easily use up your 6 tries.
  4. When you’ve overworked the interlock, often the tongue or groove of a plank will shear off, rendering the plank useless.  These planks can sometimes be saved, however, by carefully reattaching the sheared-off lip with wood glue and letting it dry overnight.
  5. If you run just a few inches short on the underlayment fabric, you can avoid going out to buy more for just that little space by substituting newspaper folded to the thickness of the underlayment. They shouldn't be more than a few inches wide.
member comments
Related Articles
Laminate Flooring: Cheaper Options with Lasting Appeal Laminate Flooring: Cheaper Options with Lasting Appeal
If you want the look of marble or bamboo flooring in your home, but cannot... read more
Is Slate Laminate Flooring a Decent Alternative?
Slate laminate flooring is laminate flooring that is designed to imitate the appearance of slate... read more
Bamboo Laminate Benefits and Drawbacks
Bamboo laminate has become an extremely popular as environmental awareness has made bamboo flooring the... read more
articles we like
Customize Your Window Treatments
Custom window treatments let you coordinate the style, pattern and color of your window treatments... read more
Site Work
Site work is a term used to describe any work done when preparing a site... read more
Poor economy creates demand for new CPAsPoor economy creates demand for new CPAs
Good news can be found, even when the economy is down and unemployment rates up... read more
sponsored articles of the day
diy centers
