cancel
Job type :
Zip Code :
community forums
comments
Leaky Bathtub Faucet Help
After years of use, a bathtub faucet can develop a leak, but you can fix your leaky bathtub faucet in a few simple steps:
  • Turn off the water and then remove the screw in the handle of the faucet.
  • Pry off the faucet handle. If it is frozen in place, spray lubricant on it and work it loose.
  • Unscrew the valve from the housing.
  • Remove the screw at the end of the valve and take out the washer.
  • Replace the old washer with the new one and tighten the screw.
  • Wrap the housing thread on the outside of the valve with Teflon tape to prevent it from leaking at the handle.
  • Screw the valve back in the housing.
  • Replace the handle back in its place.
  • Start the water and check for leaks.
member comments
Related Articles
More Home Water Treatment Information
How and Why To Buy A Home Water Treatment Unit including how tos, FAQ's and... read more
Tub Faucet Repair: How to Prevent Future Leaks
Letting a leak continue without any type of tub faucet repair can result in several... read more
Protecting Your Pipes
Protecting Your Pipes... read more
articles we like
Structural Timbers
Structural timbers are wood pieces larger than 4X6, used in framing and structural construction. Structural... read more
Window Security Film
Window security film is a heavy plastic film that is applied to windows in order... read more
Experience the rewards of an advanced education  Experience the rewards of an advanced education
Today's job market is very competitive. With an advanced degree, your earning potential can greatly... read more
sponsored articles of the day
diy centers
