cancel
Job type :
Zip Code :
community forums
comments
Kids' Bed Slide Setup Step-by-Step
A kids bed slide is one way that parents can make going to bed fun and enjoyable for both children and adults. Put a slide on a child’s bunk bed or loft bed for an exciting and fun addition to a kid’s room.
Supplies Needed
  • Power drill
  • Measuring tape
  • 4 inch bolts, washers and nuts
  • Wood Screws
  • 2 X 4 inch wood
  • Pre-fabricated  plastic slide
Step 1
Measure the size of your child’s room and the space you will have for a slide. Be sure there is enough area between the bed and the wall to allow for the drop of a slide. Measure the height of the bed or loft. Make note of whether or not the bed can be adjusted to different heights to accommodate different slides.
Step 2
Preformed plastic slides are the safest option for use in a child’s room. Purchase a slide at a home improvement store or recreational equipment supply store. These slides come in a variety of lengths and configurations.
Be sure to buy the height of slide that will fit your child’s bed.
Step 3
Make adjustments to the bed height, if needed. If you have a wooden bed, you can build up extra height by adding lengths of 2 x 4 as needed.
Use a drill to make holes for the bolts. Bolt the wood pieces securely to the bed frame.
To attach a slide to a metal frame bed, you will need to bolt a piece of 2 x 4 lumber to the bed. Use a metal bit to drill through the frame under the mattress. Do not try to install a slide attached to a round metal pole.
Step 4
Install the slide according to manufacturers directions. Generally speaking, you will use two smooth headed bolts at the top of the slide. Drill through the 2 X 4 to attach the bolts. Tighten securely underneath the slide.
Step 5
Secure the slide to the floor with 2 inch wood screws. This will cause minimal damage to carpets and it is necessary for the safety of your child.
Step 6
Apply pressure to the slide to ensure that it is secure. Instruct your child to use proper safety precautions.
member comments
Related Articles
Think about the unthinkable: Protect your family with life insuranceThink about the unthinkable: Protect your family with life insurance
If you've been thinking about buying life insurance, now is the time because term life... read more
A Buyer's Guide to Smart Life Insurance Shopping
This series discusses the smart way to select and buy a wide variety of different... read more
Is Whole Life a Good Investment?Is Whole Life a Good Investment?
Good investments are hard to come by right now. You may have heard permanent life... read more
articles we like
Support Columns
Support columns are used to help raise floor joists so that floors don't sag. If... read more
Removing Window Tint From Your Car
If you want to remove window tint first consider the fact that most window tinting... read more
Online Tools Help You Find the Right Health InsuranceOnline Tools Help You Find the Right Health Insurance
Are Americans paying too much for health insurance? While health care costs continue to skyrocket,... read more
sponsored articles of the day
diy centers
