cancel
Job type :
Zip Code :
community forums
comments
Installing Glueless Laminate Flooring: A Step-by-Step Guide
Glueless laminate flooring is relatively easy to install and requires only a few basic tools to complete the task.
Make Preparations
The first step in installing glueless laminate flooring is to measure the area in which it will be installed. You’ll want to make sure that you have enough material on hand to complete the project. When you purchase the materials, always remember that the boxes of flooring must lay flat. They must also be left in the room in which they are to be installed for at least 48 hours prior to installation.
Step 1 – Remove Molding
Remove any molding around the floor except the baseboards. If there is carpet on the floor, that must be removed as well. While this type of flooring can be installed on most surfaces, it cannot be installed over carpet. If there are any “valleys" in the floor that are deeper than 1/8 of an inch, then you will have to use a leveling compound to make the floor level. Sweep the floor clean before beginning work.
Step 2 – Install Underlayment
There is an underlayment material that must be installed under the glueless laminate flooring if the flooring doesn’t already have it attached. This is sort of a foam material that reduces noise among other things. Remember that this is a “floating” style floor and the underlayment will eliminate squeaking and other noises.
Step 3 – Install the Flooring
Now you are ready to install the glueless laminate flooring. Follow the instructions provided with the material for proper installation. Remember that when the instructions call for tapping the plank into place to use a block of wood or other material to prevent damaging the track.
member comments
posted Sep 26, 2009
Wow. Could this be any LESS helpful? Step 3-Follow the installation instructions. Gee, thanks for THAT tip. It never would have occurred to me...
Related Articles
Glueless Laminate Flooring: Benefits and Drawbacks Explained
Glueless laminade flooring is laminate flooring that can be installed without using glue... read more
Bamboo Laminate Benefits and Drawbacks
Bamboo laminate has become an extremely popular as environmental awareness has made bamboo flooring the... read more
Is Slate Laminate Flooring a Decent Alternative?
Slate laminate flooring is laminate flooring that is designed to imitate the appearance of slate... read more
articles we like
Outdoor Chair
An outdoor chair can be a variety of chairs used in outdoor settings which have... read more
Ribbon
In construction terms a ribbon refers to a board or lengths of board which are... read more
Hidden Vacation Deals are Waiting to Be FoundHidden Vacation Deals are Waiting to Be Found
Shopping around for travel deals has never been easier, thanks to the Internet. The hardest... read more
sponsored articles of the day
diy centers
