cancel
Job type :
Zip Code :
community forums
comments
Installing Bifold Door Lock Hardware
Installing door lock hardware on a bifold door is a simple and inexpensive DIY project. Locking your bifold doors is a great way to keep valuables out of your children's reach or add additional privacy. Follow these simple steps for a quick installation project.
Materials Needed:
•Child proofing plastic lock or a metal door flush or surface lock
•Electric drill with drill bit and screwdriver bits
•Screws
Step 1-Choose a Lock Style
There are two general bifold door lock styles from which you can choose:
Plastic child safety locks slide over the top of the bifold door, covering the joint where the two pieces of the door meet. The plastic childproofing lock is best for a temporary measure, when you will want to remove the lock permanently after a time.
Metal door flush locks or surface locks are best for doors where you permanently want the option to lock your door.
Step 2-Adjust the Door
If you are using a plastic, slide on, childproofing lock, you may need to adjust the door in order to get clearance enough to install the lock. If this is the case with your door, find the nut on the lower edge of the door. Turn it until it lowers the door adequately without causing the upper slide to jump out off its track.
For the flush or surface mount lock, be sure the door is close enough to the top of the door frame that the lock can engage.
Step 3-Locate the Lock
The plastic childproofing lock can be slid into place over the folding area of the door. Use shims to tighten the fit if the door is particularly narrow. Lock the handle into place. To release the door, unlock the handle to the side.
For a flush mount lock, choose a location on the section of door farther away from the section where the swivel is attached to the floor. Locate the lock approximately one inch from the center hinge, on the section farthest from the swivel.
Step 4-Complete Installation
Drill a hole according to the flush mount lock instructions directly above the location you have chosen for the lock. Install the lock plate with screws.
Align the slide into the lock plate and place the lock on the door. Mark the screw locations, unlock the lock and carefully screw the sliding lock onto the exterior of the sliding door. Since this is a permanent installation, choose a flush mount or surface lock in the same finish as the other hardware in the room.
member comments
Related Articles
Bi-Fold Door Installation Step-By-Step
Installing a bifold door can be a fairly simple process if you are willing to... read more
Door Knob ChoicesDoor Knob Choices
It may not be the first thing that comes to mind when you’re designing your... read more
How a Door Lock on a Doorknob Works
For security purposes, most doors are equipped with one of two types of door lock... read more
articles we like
Outdoor Chair
An outdoor chair can be a variety of chairs used in outdoor settings which have... read more
Splash Block
A splash block is a small block usually manufactured using concrete which is shaped in... read more
Looking for an Affordable European Vacation? Visit GermanyLooking for an Affordable European Vacation? Visit Germany
Think the dollar's recent poor performance against the Euro means you can't afford to vacation... read more
sponsored articles of the day
diy centers
