cancel
Job type :
Zip Code :
community forums
comments
Installing a Pot Filler Faucet Above Your Stove
A pot filler faucet is the ultimate in convenience and utility for the cook. It is another example of the great commercial-kitchen features that are finding their way into the home kitchen because of their convenience and utility.
Step One – Take Measurements
To be sure you put the pot filler faucet at the right height, when taking measurements, you need to consider: the technical dimensions from the manufacturer, the height of the cook top burners above the countertop, and the height of your tallest pot.
Since the faucet folds against the wall when not in use, you also need to consider swing-away space. Make sure the faucet won’t hit your cabinets or mar any other surface.
Step Two – Consider the Design
You may want a model with two valves and a separate ball valve in the plumbing. The separate-ball valve allows you to turn off the water in order to adjust the pot filler faucet if it needs repairs.
Step Three – Install the Faucet
Installing the faucet involves drilling through the backsplash behind the cook top, hooking into existing plumbing (or bringing plumbing to the area), installing the ball valve, and installing the faucet.
member comments
Related Articles
Home Water Treatment Information
Finding the right water treatement without the pressures of a salesperson... read more
More Home Water Treatment Information
How and Why To Buy A Home Water Treatment Unit including how tos, FAQ's and... read more
Tub Faucet Repair: How to Prevent Future Leaks
Letting a leak continue without any type of tub faucet repair can result in several... read more
articles we like
Painting Countertops
Painting countertops has become a popular alternative to replacing laminate countertops, so let’s look at... read more
Dry Cleaning
The process of dry cleaning, just as the name implies, is cleaning garments and textiles... read more
Replace your contact lenses without paying a fortuneReplace your contact lenses without paying a fortune
As your contacts age -- or as you start to run out of disposables --... read more
sponsored articles of the day
diy centers
