In areas of drought or poor growing situations, installing an artificial greens or garden area may be beneficial. Artificial greens have come a long way in terms of look and quality – not the old Astroturf of years ago.
Benefits of Artificial Greens
- Year long lush green grass
- No mowing or trimming, which cuts down on emissions from mowers
- No weeds
- UV stable
- No allergies
- Prevents use of pesticides, fertilizers and weed killers that can pollute the ground
- No need to water
- Can be made from recycled materials
Installation of Artificial Greens
Installing artificial greens will save time and money over the long run with no need for maintenance. In typical circumstances the surface is expected to last 15-20 years. While installation can be done by a homeowner, it is better left to a professional who understand drainage and ground leveling.
It is recommended to remove existing grass from the area first and dig out where the artificial greens will be installed. It may be necessary to lay a fill to level out areas of uneven ground. Layers of gravel and even a thin cushion will be applied in order to give the artificial green proper drainage, as well as a long lasting installation. Various densities of cushion or shock pads can also be used if children play in the area to provide a softer surface.
Questions of a Do It Yourself nature should be submitted to our
