A clean dryer vent lint trap is so important because not only does it lead to greater efficiency in your dryer, but will also prevent any kind of fire hazard in your home.
Lower Efficiency
When there is so much lint, the dryer has to work much harder than usual, and eventually is working much harder than it was made to work. As you may imagine, this also causes the dryer to function less efficiently. It takes longer for clothing to dry, and the dryer heats up to a higher temperature.
Fire Hazard
The buildup of lint in your dryer lint trap and your dryer vent hose is the greatest fire hazard you will have in your home. In fact, firefighters say that the most common type of house fires they fight are dryer fires caused by lint buildup. While shorts and high load on the electrical components cause some of the dryer fires, the underlying cause of these problems is a build up of lint in the dryer, especially in the vent and the lint trap.
How You Can Clean the Vent Trap
It is generally very easy to remove the lint trap and remove lint. Every month or two, you should thoroughly clean it by using a soft brush and dish soap, especially if you use fabric softener sheets. These sheets can completely close up the mesh in the lint trap.
Questions of a Do It Yourself nature should be submitted to our
