cancel
Job type :
Zip Code :
community forums
comments
Garbage Disposal: Repair and Info
Garbage Disposal: Repair and Info By Dave Donovan
If appliances were movie stars, then garbage disposal repair would be in the tabloids every week. Garbage disposals have been one of the more controversial appliances in recent history. It was actually banned in New York City until 1997. The ban was put in place because officials believed that the garbage being sent down the drain would have a damaging effect on the city's sewer system. As a matter of fact, in countries in Europe and in the U.K., it's still hard to find people who own one. They've also become known as one of the deadliest appliances in the house. That is, if you believe every horror movie you've ever seen. It never ends well when someone drops a ring down the drain. Despite the bad rap and bad-boy image, the garbage disposal is still one of our most used appliances in the kitchen today.
Many people associate the spinners inside the garbage disposal with the actual blades. That's incorrect. The spinners are actually dull and are used to push the food toward the outside edges of the disposal, which is where the shredders are. Here's how a garbage disposal really works.
Food items get stuffed into the disposal through the sink drain. Inside the disposal there are a series of spinners that spin freely, which are sometimes called "the hammers." The hammers are connected to a turntable that is spun around by the motor. Along the outer wall of the disposal are the shredders. When you turn the disposal on, the motor spins the turntable at an extremely high speed. This causes centrifugal force that pulls the food outward towards the shredder. The hammers spin around and assist with pushing the food into the shredder. The shredder tears the food into tiny parts that get flushed down the drain along with the water. Garbage disposals should never be run without the water running. They are dependable appliances, but let's see if you've ever had this experience:
You just had a big dinner and instead of throwing the debris left on the dishes into the garbage, you choose to stuff it all down the drain (make sure no silverware sneaks in!). You hit the switch on the wall, the disposal screams to life and then... nothing. You flip the switch a couple of times only to be met with a humming and then a "click." Now when you hit the switch, you don't even get the humming.
This is a common problem and an easy one to fix. This is just one of the problems you may face with your garbage disposal. Ahead, we'll look at more, but first let's fix this one.
When something makes the garbage disposal clogged, there is a button underneath that trips out. It's best to wait about 15 minutes and then hit the reset button. It's located on the bottom of most disposal systems, and it's usually colored red. If you push it in and you hear a "click," then it's been reset. With the water running, try turning the disposal on again. If it's really jammed, it will probably trip again. If it does, leave the switch off and don't hit the reset button yet. Remove any large items from the disposal with a pair of tongs - don't forget the scary movies! Next, grab a long screwdriver and try to get it to catch hold in one of the bottom holes on the turntable. Once it catches, try to manually turn the turntable to help break the jam. Once you free the obstruction, remove the screwdriver, hit the reset button, turn the water on, and hit the switch. It should be running smoothly now. Throw the big debris in the garbage can next time!
Now, let's look at a few other problems and their remedies.
Problem: The disposal isn't running at all.
Solution: It could be the problem we just discussed, or it could be a power problem. Check the power to the circuit that feeds the disposal. If the breaker is OK, then check the power at the switch. If you have power coming to, but not leaving the switch, then the switch is bad. Turn the circuit off and replace the switch.
Problem: The disposal is draining poorly.
Solution: Make sure that the water is running full blast when using the disposal: the more water, the better drainage. If it's still draining slowly, disconnect the "J" bend in the drain and check for a clog. Sometimes grease and other nasty things will accumulate in your pipes over time.
Problem: The disposal is leaking.
Solution: If it's leaking around the drain, try tightening the screws on the sink mounting ring. You will need an offset screwdriver to be able to reach the screws once the disposal is already assembled. If the leak is coming from the drainpipe, tighten the screw that holds the drain gasket. If the leak persists, try replacing the drain gasket.
Problem: The garbage disposal noise is out of control.
Solution: While it's not the quietest appliance in normal situations, it can become really noisy if something gets in there to cause a ruckus. With the switch off, grab a flashlight and take a look down the drain and see if you notice anything that can be causing the noise. Plastic or metal items are usually the culprits. Fish out the item with tongs. If there's nothing in the disposal, check the mounting screws. They could be loose enough that when it's turned on, it vibrates enough to cause a lot of noise. It could also mean that you have a damaged flywheel. If that's the case, you're better off buying a new disposal than trying to replace that.
All in all, the garbage disposer's not that bad a guy. He's dependable, he's there when you need him, and he doesn't complain about taking out the trash. With these simple repairs, your relationship with this bad-boy should last for years. If you don't have a garbage disposer yet or would like to install a new one, read our step-by-step installation guide here.
member comments
Related Articles
Garbage Disposer Tips
Several tips to keep your garbage disposal working smoothly... read more
Types of Sinks and the Purpose they Serve
This article looks at the different kinds of sinks there are and the purpose each... read more
Install a Garbage Disposer, Step by Step
A step-by-step instruction guide to installing a new garbage disposal under your kitchen sink... read more
articles we like
Granite Countertop Colors
Black is the most common granite countertop color. This has led to the perception that... read more
Stroke Risk
Stroke risk is the list of factors that contribute to stroke. Stroke risk factors are... read more
The Easy Way to Learn a Foreign LanguageThe Easy Way to Learn a Foreign Language
Want to learn a new language? You may think it's so hard you won't have... read more
sponsored articles of the day
diy centers
