cancel
Job type :
Zip Code :
community forums
comments
How To Stain An Oak Cupboard
Staining an oak cupboard is an easy and rewarding task that can enhance the beauty of your home. However, as easy as it can be to stain an oak cupboard, it is just as easy to make a mess. With a few guidelines and a little effort and patience your cupboard will be looking beautiful in no time.
Materials and Tools
  • Wood putty
  • Sandpaper (medium and fine grit)
  • Latex or nitrile gloves
  • Paint brush or cheese cloth
  • Stain (color of your choice)
  • Paint thinner
  • Polyurethane or shellac (optional)
Step 1 - Preparing the Surface
Start by putting wood putty in nail holes or damaged areas like cracks and dents. This will give the wood a flat even finish before staining and the wood putty is stainable as well. After the putty has had time to set and dry sand it smooth with a medium sandpaper flush with the surface of the wood.
Step 2 - Applying the Stain
The application is pretty simple. Make sure that you wear protective gloves and old clothes since stain soaks into the wood and skin equally.  Using a good quality paint brush or preferably cheese cloth or rag apply your stain. The cheese cloth pushes the stain into the grain of the wood easier then the brush.
As you apply the stain go in the same direction every time. This lets keeps your stroke pattern the same across your piece. The important part here is to not over due your stain; drips and runs can discolor your cupboard or cause odd streaks. Allow the stain to set and then reapply for a darker color or if your happy with it let it dry and prepare to coat it with your top coat.
Step 3 - Apply or Polyurethane or Shellac
This is an optional step its not necessary and because some stains have polyurethane in it. If you do add a separate finish to your cupboard you should know that polyurethane comes in different finishes (i.e. satin, semi-gloss, etc). This step is the most time consuming as you apply make sure you don't allow runs or bubbles. These can occur if the finish is applied to thick or is allowed to run. Clean up runs before it sets and just keep an eye on it. After it sets inspect your cupboard and if needed sand it with the fine sandpaper and reapply.
If you take your time and don't rush the applications you will have a beautiful piece.
member comments
Related Articles
Secrets of Kitchen RemodelingSecrets of Kitchen Remodeling
Upgrading your kitchen is a sure-fire way to increase your home's value. You'll love your... read more
Making Your Kitchen Remodeling Contractor Your Best FriendMaking Your Kitchen Remodeling Contractor Your Best Friend
Everyone knows a kitchen remodel pays big in terms of increased home value and improved... read more
Kitchen Center
Kitchen Options At DoItYourself.com... read more
articles we like
Granite Countertop Colors
Black is the most common granite countertop color. This has led to the perception that... read more
Do It Yourself Gutter Repair Tips
Advice and tips for cleaning and repairing your home's gutters... read more
Do You Need Life Insurance?Do You Need Life Insurance?
Of course insurance companies always say you need insurance, but depending on what stage you're... read more
sponsored articles of the day
diy centers
