cancel
Job type :
Zip Code :
community forums
comments
How To Space Deck Boards
Ensuring your deck boards are spaced properly will prevent damage and weathering. When spacing deck boards, keep these tips in mind.
Nails
Sixteen penny nails are the best way to establish the amount of space needed between your deck boards. Just place the nail in between the boards to ensure you have enough space. This will allow water to drain in between the boards and not pool-up, causing damage to the deck. Make sure the boards are dry when you begin spacing them.
Straighten
It’s rare to have perfectly straight boards. You will need to straighten the boards before they can be spaced. Using a flat bar is the best way to accomplish this. It needs to fit snugly, and you may need to use a hammer to get the desired straightening against the joists.
Joints
If your building a larger deck that requires joints, their spacing and placement are important as well. Use the same sixteen penny method and try to avoid placing joints on the same joist too often. Staggering the joints as much as possible makes for a much nicer looking deck.
member comments
Related Articles
Deck Building 2 - Preparation for Deck Construction
This section prepares you for what to do during pre-construction of your sun deck. It... read more
Deck Building 4 - Determining Level and Length of Ledger
This section educates you on the first step to building a sun deck, determining the... read more
How to Design a Deck
Stept by step instructions to designing and planning the deck of your dreams... read more
articles we like
Bidet Toilets
Sometimes referred to as paperless toilets, bidet toilets offer an alternative personal cleansing method to... read more
Outdoor Chair
An outdoor chair can be a variety of chairs used in outdoor settings which have... read more
Use Artificial Plants to Achieve Feng Shui When You RedecorateUse Artificial Plants to Achieve Feng Shui When You Redecorate
Redecorating your living space for comfort and style can be challenging -- and fun! Decide... read more
sponsored articles of the day
diy centers
