ON TO PART 3
by Guy Cozzi
The first step to taking a whole-house energy efficiency approach is to find out which parts of your house use the most energy. A home energy audit will show you where these are and suggest the most effective measures for reducing your energy costs. You can conduct a simple home energy audit yourself, or contact your local utility, or call an independent energy auditor for a more comprehensive examination.
Formulating Your Plan: After you have identified places where your home is losing energy, assign priorities to your energy needs by asking yourself a few important questions:
- How much money do you spend on energy?
- Where are your greatest energy losses?
- How long will it take for an investment in energy efficiency to pay for itself in energy savings?
- Can you do the job yourself, or will you need to hire a contractor?
- What is your budget and how much time do you have to spend on maintenance and repair?
Once you assign priorities to your energy needs, you can form a whole-house efficiency plan. Your plan will provide you with a strategy for making smart purchases and home improvements that maximize energy efficiency and save the most money.
A home energy audit is the first step to assess how much energy your home consumes, and to evaluate what measures you can take to make your home more energy efficient. An audit will show you problems that may, when corrected, save you significant amounts of money over time. During the audit, you can pinpoint where your house is losing energy. Audits also determine the efficiency of your home’s heating and cooling systems. An audit may also show you ways to conserve hot water. You can perform a simple energy audit yourself, or have a professional energy auditor carry out a more thorough audit.
Do-It-Yourself Audits
You can easily conduct a home energy audit yourself. With a simple, but diligent, "walk-through," you can spot many problems in any type of house. When auditing your home, keep a checklist of areas you have inspected and problems found. This will help you prioritize your energy efficiency upgrades.
1) Locating Air Leaks: First, make a list of obvious air leaks (drafts). The potential energy savings draft reduction may range from 5% to 30% per year, and the home is generally much more comfortable afterwards. Check for indoor air leaks such as gaps along the baseboard or edge of the flooring, and at junctures of the walls and ceiling. Check to see if air can flow through electrical outlets, switch plates, window frames, baseboards, weather-stripping around doors, fireplace dampers, attic hatches, and wall- or window-mounted air-conditioners. Look for gaps around pipes and wires, electrical outlets, foundation seals, and mail slots. Check to see if the caulking and weather-stripping are applied properly (no gaps or cracks), and are in good condition.
Inspect windows and doors for air leaks. See if you can rattle them, since movement means possible air leaks. If you can see daylight around door and window frames, then the door or window leaks. You can usually seal these leaks by caulking or weather stripping them. Check the storm windows to see if they fit and are not broken. You may also wish to consider replacing your old windows and doors with newer, high-performance ones. If new factory-made doors or windows are too costly, you can install low-cost plastic sheets over the windows.
If you are having difficulty locating leaks, you may want to conduct a basic building pressurization test. First, close all exterior doors, windows, and fireplace flues. Turn off all combustion appliances such as gas burning furnaces and water heaters. (Remember to turn them back on when you are done with the test.) Then turn on all exhaust fans (generally located in the kitchen and bathrooms) or use a large window fan to suck the air out of the rooms. This increases infiltration through cracks and leaks, making them easier to detect. You can use incense sticks or your damp hand to locate these leaks. Moving air causes the smoke to waver, and you will feel a draft when it cools your hand.
On the outside of your house, inspect all areas where two different building materials meet. For example: inspect all exterior corners; where siding and chimneys meet; and areas where the foundation and the bottom of exterior brick or siding meet. You should plug and caulk holes or penetrations for faucets, pipes, electric outlets, and wiring. Look for cracks and holes in the mortar, foundation, and siding, and seal them with the appropriate material. Check the exterior caulking around doors and windows, and see whether exterior storm doors and primary doors seal tightly.
CAUTION: When sealing any home, you must always be aware of the danger of indoor air pollution and combustion appliance "back drafts." Back drafting is when the various combustion appliances and exhaust fans in the home compete for air. An exhaust fan may pull the combustion gases back into the living space. This can obviously create a very dangerous and unhealthy situation in the home!!
In homes where a fuel is burned (i.e., natural gas, fuel oil, propane, or wood) for heating, be certain the appliance has an adequate air supply. Generally one square inch of vent opening is required for each 1,000 Btu of appliance input heat. When in doubt, contact your local utility company, energy professional, or ventilation contractor.
Questions of a Do It Yourself nature should be submitted to our
