cancel
Find Qualified
Local Contractors
Select Service:
Enter Zip:
community forums
How to Save on Heating Costs
comments
Here are tips and instructions on how to insulate your home. Take a few minutes to read them thoroughly. Following these instructions can save you time and effort.
In this document you will find information about:
  • How Insulating Your Home Saves Money
  • Types of Insulation
  • How Much Insulation You Will Need
  • Spreading Loose-fill Insulating Materials
  • Applying Insulation in Blanket Form
  • Insulating Walls
HOW INSULATING YOUR HOME SAVES MONEY
  • Heating and cooling your home accounts for about 50 percent to 70 percent of the energy used in your home. Unless your home was built as an energy-efficient home, adding insulation will probably reduce your utility bills. Even a small amount of insulation–if properly installed–can reduce energy costs dramatically.
  • You should insulate all areas of your home. Insulation priorities include your attic, including the attic access door, under floors above unheated basements or crawl spaces, and on the edges of concrete slabs. Your options for insulating existing walls are somewhat limited. However, if you are remodeling or residing your home, use the amounts of insulation recommended for new construction. Figure 1 shows you where to insulate and also contains the range of recommended R-values for each of those areas in your house. The R-value changes because of the type of heat you use and where you live. It also changes between new and existing homes. To find the recommended R-value for the area of the country you live in, contact your local electric company or gas company. You can also find the recommended R-value by zip code and heat source at the Department of Energy Web site, www.eren.doe.gov.
  • It's interesting to note that the greatest energy savings come from the first inch of insulation installed. You can add more insulation to increase your savings, but a small amount of insulation is almost a must for your home to be comfortable. Keep in mind that for insulation to work properly the air spaces in the insulation must be maintained. Packing too much insulation into an area will reduce the effectiveness of the insulation.
  • Savings from wall insulation are almost equal to those you'll get from ceiling insulation.
  • You can further increase your energy savings, up to 10 percent, by plugging any air leaks prior to insulating. Obvious air leaks can be found around doors, windows, fireplaces and chimneys. Some not-so-obvious air leaks can be found around electrical switches and outlets, pull-down attic stairs, pipes, and behind bathtub and shower stall units. These leaks are often much greater than the obvious ones. However, taking care of these leaks alone cannot do the job–you must also have insulation.
R-values change by location and by heat sources. They also change between new and existing homes. These are only ranges. find the specific recommended R-value for your home.
TYPES OF INSULATION MATERIAL AVAILABLE
  • Most insulating materials are available in several common forms–loose-fill or spray-applied materials, blanket rolls, batts, boards and foil-faced paper, foam, film and cardboard. Each form is ideal for specific insulating jobs.
  • The type of insulation material you select for any job depends on how you intend to use it, how much you want to spend, and how easy it is to install.
  • Figure provides a summary of the qualities and suggested uses for the basic types of insulation.
  • Study figure carefully. Consider the advantages, disadvantages and instructions for using each type of material as outlined in the chart. This table should help you select the correct material for any insulation job.
  • Blanket and batt insulation is usually made from fiber glass or rock wool. It is sized to fit between studs, floor joists and ceiling joists. It comes both faced and unfaced. Faced means the batt or blanket has a cover such as paper or foil on one side. Unfaced means there is no cover. Some batts and blankets now come with a protective covering that reduces the "itchy feeling" you get when you work with insulation.
  • Rigid foam insulation is widely used on basement walls and on exterior walls. If rigid foam is used inside, it must be covered with gypsum board or other building code-approved material for fire safety reasons. When it is applied on the outside, it must be covered with a weatherproof facing. When using a foil-covered rigid foam, the foil must be away from the heated side of the wall to avoid a condensation problem.
TYPES OF INSULATION
Form Method of Installation Where Applicable Advantages
Blankets: Batts or Rolls
Fiber glass Rock wool
Fitted between studs, joists and beams All unfinished walls, floors and ceilings Do-it-yourself
Suited for standard stud and joist spacing, which is relatively free from obstructions
Loose-fill (blown-in) or Spray-applied
Rock wool
Fiberglass
Cellulose
Polyurethane foam
Blown into place or spray applied by special equipment Enclosed existing wall cavities or open new wall cavities
Unfinished attic floors and hard-to-reach places
Commonly used insulation for retrofits (adding insulation to existing finished areas)
Good for irregularly shaped areas and around obstructions
Rigid Insulation
Extruded polystyrene foam (XPS)
Expanded polystyrene foam (EPS or beadboard)
Polyurethane foam
Polyisocyanurate foam
Interior applications: Must be covered with 1/2"gypsum board or other building-code approved material for fire safety
Exterior applications: Must be covered with weather-proof facing
Basement walls
Exterior walls under finishing (Some foam boards include a foil facing which will act as a vapor retarder. Please read the discussion about where to place, or not to place, a vapor retarder)
Unvented low slope roofs
High insulation value for relatively little thickness
Can block thermal short circuits when installed continuously over frames or joists
Reflective Systems
Foil-faced paper
Foil-faced polyethylene bubbles
Foil-faced plastic film
Foil-faced cardboard
Foils, films or papers: Fitted between wood-frame studs, joists and beams Unfinished ceilings, walls, and floors Do-it-yourself
All suitable for framing at standard spacing. Bubble-form suitable if framing is irregular or if obstructions are presentt; effectiveness depends on spacing and heat flow direction
HOW MUCH INSULATION YOU WILL NEED
  • On a new home, find out what the recommended R-value is for the type of heat you are planning to use for the location of your new home. Again, local electric and gas companies can provide this information to you or you can contact the Department of Energy.
  • On an existing home it is a little more complicated, but not hard. First, you need to identify what type of insulation is currently in your home. It may differ by the various locations in your home. In your attic for example, you may find batt or blanket fiber glass over the top of loose-fill cellulose. You may also find multiple layers of batt or blanket insulation. Next, you need to measure the thickness of each of these different types of insulation at the different locations. To help you with this process, take a regular sheet of notebook paper and make four columns. Label the first column "Location," the second column "Type Of Insulation," the third column "Inches Thick" and the fourth column "R-value per Inch."
  • Figure shows you the approximate R-value each inch of the various types of insulating materials provides. Use this chart to fill in the last column of your worksheet. One inch of fiber glass batts or blankets, for example, provides an approximate R-value of 3.2. To find the R-value of 4" of fiberglass, multiply 4 x 3.2 to get an R-value of 12.8. Repeat this process of multiplying the number of inches thick and the R-value per inch of insulation for each area in your home. If you have two different types of insulation together, like our earlier example, find the R-value for each and then add them together.
    R-VALUE
    Insulation Type R-Value per inch
    of thickness
    Fiber glass blanket or batt 3.2
    High-performance fiber glass blanket or batt 3.8
    Loose-fill fiber glass 2.5
    Loose-fill rock wool 2.8
    Loose-fill cellulose 3.5
    Perlite or vermiculite 2.7
    Expanded polystyrene board 3.8
    Extruded polystyrene board 4.8
    Polyisocyanurate board, unfaced 5.8
    Polyisocyanurate board, foil-faced 7.0
    Spray polyurethane foam 5.9
  • Let's use an example where we have 6" of cellulose covered by 6" of fiber glass batts in the attic. We take the R-value of cellulose, which is 3.5 and multiply it by 6 to get 21.0. We then take the R-value of fiberglass batts, which is 3.2 and multiply that by 6 to get 19.2. Since the insulation is layered one on top of the other, we add them together 21.0 + 19.2 to get 40.2.
  • If we live in a region where the recommended R-value is 38, we already have 40.2, so we do not need to add insulation. What happens though, if we live in a region that recommends 49–we need to add some insulation, but how much? That's easy too! Take the recommended R-value, which is 49, and subtract what we have already, which is 40.2 (49 - 40.2 to get 8.8). We need to add an R-value of 8.8. The R-value of an inch of fiber glass batts is 3.2. Divide the amount we need to add, 8.8, by the R-value per inch, 3.2, to get 2.75. Batt and blanket insulation comes in several thicknesses. One of these is 3-1/2". So one layer of 3-1/2" fiber glass batt insulation added to what we have will give us a little more than what we need. It is always ok to add more insulation than is recommended. Just remember not to pack it too tightly because packing it can reduce its effectiveness.
SPREADING LOOSE-FILL INSULATING MATERIALS
  • Loose-fill insulating materials of rock wool, fiber glass or cellulose are commonly used for insulating attics. Vermiculite is not currently used for homes, but it may be found in older homes. It is best to install these materials with a plywood rake attached to a rake handle, making spreading much easier.
  • To make this type of rake, cut a scrap piece of plywood to the length of the space between the joists plus 4". The extra 4" allows for an overhang on the joists.
  • Next decide how deep you plan to install the loose-fill material. For example, suppose you are planning to lay the loose-fill material to a depth of 3" between the attic joists. Measure the depth in the space you plan to fill then saw the plywood rake as illustrated. The rake should ride on the joist on either side and level the material off evenly to a depth of 3". Attach a handle, making a handy tool that will save you hours of backbreaking labor and enable you to rake the material easily and evenly into otherwise unreachable corners.
Loose-fill insulation material is spread easily with a plywood rake cut to the correct size and depth.
Cut a piece of plywood and make a rake for applying any type of loose-fill materials
APPLYING INSULATION IN BLANKET FORM
  • Always apply blanket-type insulation with the vapor barrier facing the interior of your home. The vapor barrier should always be toward the source of heat in the winter. Never place a vapor barrier between two layers of insulation. This can lead to a condensation problem and reduce the effectiveness of the insulation. Lay the blanket as close to the joists and floor as possible. Fill any gaps with loose-fill insulation or place another layer of blanket insulation across the previous layer.
  • Always place insulation on the outside of pipes or ducts. This means the insulation should be between the outside wall and the pipes.
  • When using blanket insulation, always place the vapor barrier toward the heat source and insulation outside of any pipes.
  • Staple blanket insulation when laid between joists in the attic. Most rolls of blanket insulation materials have flanges that can be stapled or tacked to the ceiling joists, as illustrated. Always keep the blanket as close to the joists and floor area as possible–fill any gaps with strips of insulation or loose-fill insulation.
  • Never allow blanket-type insulation to cut off the flow of air and stop proper ventilation in an attic. Blanket insulation should never block the air movement from the eave vents into the attic.
  • Proper ventilation in the attic is very important in any insulation job. Make provision for air to flow in and around the eave vents and to flow out through a ridge vent roof ventilator or through a ventilator on the end of the house.
  • Blanket insulation without a vapor barrier can be wedged between existing ceiling joists. Make sure the insulation comes to the top of the plate to avoid heat loss from the penetration of wind under the insulation. Failure to pay close attention to this detail can lead to a frost line forming on cold, windy days. It will form on the inside wall where the ceiling and walls come together.
  • There are special formed inserts made of foam or plastic designed to go up next to the roof between the rafters. They help with both the airflow and the frost line. Many of them are designed to be installed during new construction. But they can be installed in an existing roof with very little extra effort.
  • In some cases, it may be easier to apply the blanket between the rafters on the roof. In this case, staple the blanket insulation directly to the rafters.
  • Repair any major tears or rips in the vapor barrier and insulation by adding additional vapor barrier and insulation to build up to the level on the normal insulation run.
  • Whether you apply the insulation to the attic roof or the floor, always double it back at the end for maximum efficiency. Illustration A shows how the blanket of insulation material can be rolled at the end between the attic joists. Illustration B shows how the same material can be doubled back between the rafters of the roof.
Staple blanket insulation from below.
Always allow for adequate air circulation in the attic, especially around vents.
Allow air to flow in and around the eave vents and out through a roof, ridge or gable vents.
Blanket insulation without a vapor barrier can be wedged between ceiling joists.
In some cases, you may want to apply the insulation between the rafters.
Always double back the roll of insulation at the end for maximum efficiency.
INSULATING WALLS
  • If possible, lay blanket-type insulating material between the studs in the wall. If you're using insulation blankets without a vapor barrier, they should be forced into the area between the studs. Then, place a polyethylene vapor barrier on the inside face of the wall. Staple the vapor barrier into place.
  • When building a new structure, insulate the full wall, including around the openings for doors and windows.
  • Use drywall with a foil back as a vapor barrier instead of polyethylene if it is more practical.
  • Blanket insulation material with a vapor barrier attached can be stapled into position.
  • When the blanket has a vapor barrier, take the time to staple or tack all sides, bottoms and tops. This increases the efficiency of the insulation.
  • Use scraps of insulation material to insulate all the cracks and crevices around doors and windows. Then use scraps of vapor barrier to seal these areas. Staple the barrier in place.
Use scraps of insulation material to insulate around openings.
TOOL AND MATERIAL CHECKLIST
  • Insulation Materials (Proper Type)
  • Staples
  • Furring Strips
  • Weather Stripping
  • Stapler
  • Handsaw
  • Face Mask (if handling specific types of insulation materials)
  • Heavy-Duty Shears
  • Tacks
  • Hand Cleaner
  • Sharp Knife
  • Hammer
  • Vapor Barrier
Check your state and local codes before starting any project. Follow all safety precautions. Information in this document has been furnished by the National Retail Hardware Association (NRHA) and associated contributors. Every effort has been made to ensure accuracy and safety. Neither NRHA, any contributor nor the retailer can be held responsible for damages or injuries resulting from the use of the information in this document.
Ask for Other "Show-How" Instruction Sheets
Additional easy-to-use instruction sheets for home do-it-yourself projects are available from your local supplier of materials. Come in and ask for "Show-How" instructions when you get ready for that next handyman project!
member comments
posted Oct 01, 2008
An easy way to reduce your heating and energy cost is by installing an intelligent heating controller such as the ones on http:\\www.heatingsave.co.uk
John
Related Articles
How to Lower Your Cost of Living
The following article provides tips on how to lower your living cost both short term... read more
Integrating the Heating and Cooling of Your Home
Integrating the heating or cooling of residential space, water, and ventilation air... read more
A Guide to Making Energy Smart PurchasesA Guide to Making Energy Smart Purchases
How to make energy-smart purchases - a guide... read more
articles we like
Stroke Risk
Stroke risk is the list of factors that contribute to stroke. Stroke risk factors are... read more
Transom Window
A transom window is a common feature in modern homes. The window rests over the... read more
Foreclosures Offer Investors Amazing Opportunity Foreclosures Offer Investors Amazing Opportunity
With an unprecedented number of foreclosures sweeping the nation, there has never been a more... read more
sponsored articles of the day
diy centers
