cancel
Job type :
Zip Code :
community forums
comments
Guidelines in Building a Custom Bathroom Vanity
A custom bathroom vanity gives your bathroom additional space and can be as creative as you desire. Additionally, the vanity can be crafted by you fairly easily by following the below guidelines.
Take Measurements
Before you start building your vanity, you need to make sure you have accurate measurements of the desired area for the vanity. By getting the most accurate and exact measurements, you can be assured the vanity will fit in the space and no adjustments will have to be made while constructing it.
Decide on Drawers and Hardware
After you’ve designed your vanity on paper, you will want to pick out the hardware. Although you have the option to create drawers on your own, you may want to purchase them already assembled. Whether you craft them yourself or purchase them, be sure that measurements will be compatible with your design. Additionally, decide on the sinks, faucets, mirrors, and other items that would best suit your design.
Get Your Material
There are many different materials to choose from to best suit your other bathroom decor. You can choose from wood, metal, or even a sturdy glass for a more modern look. When you decide what type of material you'd like to use, take your measurements with you to the home improvement store and buy the necessary lengths for your design. Be sure to stock up on a bit of extra material in the event you make a mistake during the vanity's construction.
When It's Time to Assemble
To assemble your vanity, place the base down first and attach it to the wall and floor. Then, add the counter tops and sinks to the top of the base. Last, place any other hardware or items, like drawers and mirrors, into your vanity. Once you have constructed your vanity, be sure to check that every item is functional and make an adjustments as necessary.
member comments
Related Articles
Replacing Bathroom Faucet Fixtures
If you are remodeling your bathroom, the one of the things that you are going... read more
How to Design a Bathroom
How to Design a Bathroom... read more
5 Reasons to Have a Bathroom Heater Fan
If you need to replace the exhaust fan in your bathroom, consider replacing it with... read more
articles we like
Custom Window Screens
When purchasing custom window screens you can choose what type of material or screen you... read more
Customize Your Window Treatments
Custom window treatments let you coordinate the style, pattern and color of your window treatments... read more
Hair Loss, Aging and SupplementsHair Loss, Aging and Supplements
You're fighting the effects of aging on every front you can. Or are you? Age... read more
sponsored articles of the day
diy centers
