cancel
Job type :
Zip Code :
community forums
comments
Graffiti Removal in Eight Steps
The cleaning agent you will use for graffiti removal depends on the surface material to be cleaned, like wood, vinyl, aluminum, glass or masonry. Read on to learn how to effectively remove graffiti from masonry.
Prepare the Area
Gather the necessary materials. Spread drop cloths or plastic tarps, and use masking tape and plastic sheets to cover surfaces not meant to be cleaned. Have hand-cleaner and safety goggles at the ready, as well as rubber gloves, rags, stiff wire brushes and scrapers.
Work Down
Make sure the surface is dry and clean before you begin. Start from the top of the surface and finish at the bottom, catching any running or streaking fluids as you work your way down.
Identify the Graffiti
Pressure-washing is found to be most effective in removing chalk graffiti. Spray paint will usually require some type of solvent, cleaner or abrasive. Baking soda-based products, paint thinner, acetone and WD-40 have been known to work on concrete and brick surfaces.
Test
Sometimes the trial and error method is the best approach. The first attempt should be with the least-invasive method available. This might include using a high-pressure washer (1000 to 3500 PSI) to remove graffiti from unadorned concrete. Carved masonry or architectural brickwork, however, might be vulnerable to pressures above 500 PSI. Use hot water and a wide-angle fan-type nozzle, as opposed to a concentrated jet-type spray, which can damage some surfaces.
Use a Combination
Sometimes it is best to use a solvent in addition to a pressure-washer. Apply the solution to the surface and let it settle in before using the pressure washer.
Work Large Areas
Do not focus on the graffiti itself, as this may permanently etch or 'shadow' the graffiti outline into the surface.
Apply a Preventative Coating
A non-sacrificial, permanent coating is unaffected by the graffiti removal process, while a sacrificial coating would have to be continually replaced. An example of the former is CPU 647 Barrier Coating, a waterborne polyurethane consisting of 2 compounds that are mixed together before use. Once applied, it forms a protective barrier and prevents additional coatings or markings from adhering to the surface; without a solid bond they are easier to dissolve.
Re-Paint
If all else fails, you can re-paint, but you will have to re-paint the entire surface. You may have to apply multiple coats to prevent the image from bleeding through.
Before attacking graffiti yourself, consult a graffiti-removal contractor or specialist. Local governments and municipalities will remove graffiti from public buildings, but it is the responsibility of the owner to maintain private property. There are often volunteer groups within the community that will assist homeowners with graffiti removal.
member comments
posted Oct 12, 2009
I have been remediating graffiti for a few years in my neighborhood. Some of my practices include:
1. Remove the graffiti as soon as possible to prevent positive reinforcement. Tagging attracts other taggers.
2. Clean off inks and paint crayons with Oops or other similar solvent first and then lightly sand and repaint if necessary to prevent bleed-through.
3. On Utility poles or boxes repaint with gloss enamel if possible; a glossy surface is easier to clean.
4. On block or brick work, I use a color-matched flat paint and I try to avoid painting the grout lines or I paint the grout lines with a color-matched paint.
5. Paper labels should be soaked with Oops or other solvents to soften the adhesive, then gently peel using a razor scraper or sharp, wide wood chisel.
6. Plastic labels or tape must be gently peeled first, then the adhesive removed with solvent.
Related Articles
Cleaning Used Brick: 2 Tips
Used brick is a very popular building material for walkways, garden planters, fireplace surrounds and... read more
Brick FAQsBrick FAQs
Frequently Asked Questions about brick architecture... read more
Brick Cleaning Made Easy
Brick cleaning can be just as easy as cleaning in other areas of your home... read more
articles we like
Stained Glass Windows
Stained glass windows add a colorful, distinctive accent to a home while protecting privacy... read more
Support Columns
Support columns are used to help raise floor joists so that floors don't sag. If... read more
Back to Work Thanks to a High-Tech WheelchairBack to Work Thanks to a High-Tech Wheelchair
The disabled can get a new lease on life with the help of a high-tech... read more
sponsored articles of the day
diy centers
