cancel
Job type :
Zip Code :
community forums
comments
Fixing Shower Faucet Leaks
Fixing a shower faucet leak usually involves replacing a worn O-ring. The O-ring is a small rubber ring which seals the different parts of a shower together at the joints. You may have an O-ring that slips into your blender or food processor. Your local hardware store will have a number of O-rings in different sizes. Most showers are uniform. It is a good idea to remove the old O-ring first. Then, take it to the hardware store to find the right replacement.
A Simple Repair
Remove the worn O-ring in 3 simple steps. First, remove the handle and escutcheon to expose the shower valve. The escutcheon is the plate behind the handle. There is one valve in the center, the control valve. There is a valve on either side of the control valve for hot and cold water. Second, shut both of these off with a screwdriver. You should not be able to remove the control valve cartridge. Take this part to the hardware store, and fit it for a replacement O-ring. Fixing a shower faucet may involve replacing the cartridge in some rare cases.
member comments
Related Articles
How to Conserve Energy
Advice on saving energy in different seasons and climates... read more
Tub Faucet Repair: How to Prevent Future Leaks
Letting a leak continue without any type of tub faucet repair can result in several... read more
Protecting Your Pipes
Protecting Your Pipes... read more
articles we like
Corian Countertop
A corian countertop is an easy to care for solid surface countertop that looks like... read more
Magnificent Minestrone Soup
Minestrone soup is a thick, delicious, and filling dish. It is quick and fairly easy... read more
Find better job security in a teaching careerFind better job security in a teaching career
If there were a list of glamorous careers, teaching in a public middle school would... read more
sponsored articles of the day
diy centers
