cancel
Job type :
Zip Code :
community forums
comments
Fixing a Stuck Shower Faucet Diverter
A stuck shower faucet diverter is evident if you attempt to switch the water from the main faucet to the shower head and nothing occurs. Fortunately, this is an easily fixed problem and can be performed using the following options.
Option 1-Gently Tap the Handle
Whether the diverter is a push in type or one that pulls up on the bath faucet, gently tapping the top of the handle might dislodge any buildup that is keeping it from working. If you use this option and the problem continues, you may need to use the other options listed below which involve a bit more effort.
Option 2-Pull Out With Pliers
There are two ways to perform this repair:
  1. Pull Up Faucet - Gently work the handle with the pliers, pulling it out a little at a time. Once you have retrieved it, clean it thoroughly and then place it back carefully.
  2. Push In Faucet  - Look for the screw under the faucet spout and unscrew it, enabling you to turn faucet upside down. Use needle nose pliers to pry the black rubber washer loose. Check for any debris and remove it as necessary.
Option 3-Replace If Cracked or Broken
If the shower faucet diverter is stuck because the washers are old and have broken or the plastic valve diverter inside the pipe has broken, then it is time to replace the faucet itself. The diverter is not an overly expensive mechanism to buy and replacing it may be easier than attempting to fix it.
member comments
Related Articles
Tub Faucet Repair: How to Prevent Future Leaks
Letting a leak continue without any type of tub faucet repair can result in several... read more
How to Conserve Energy
Advice on saving energy in different seasons and climates... read more
More Home Water Treatment Information
How and Why To Buy A Home Water Treatment Unit including how tos, FAQ's and... read more
articles we like
Removing Window Tint From Your Car
If you want to remove window tint first consider the fact that most window tinting... read more
Plywood
Plywood is a manufactured wood made to be strong and durable and commonly used in... read more
What Can Viruses and Spyware Do To Your Computer?What Can Viruses and Spyware Do To Your Computer?
Viruses, Trojan horses, adware and spyware can wreak havoc on your computer and make you... read more
sponsored articles of the day
diy centers
