Electrical outlet safety is very important to be aware of and understand. In order to prevent fires and other electrical outlet problems, please read the information below carefully.
Fire Hazards
One of the primary concerns with electrical outlet safety is fire safety. Most of the fires that occur within the home are due to homeowners overloading the circuits. Additionally, the following things should be avoided in order to prevent a outlet fire:
- Running cords under rugs or through high traffic areas;
- Cords and plugs and using extension cords that are too long, and;
- Incorrect wiring of the circuits.
By taking measures to check cords and plugs, you will be taking the steps to prevent a fire from starting in your outlet.
How to Avoid Problems
In order to avoid the issues with safety, there are some simple steps to take. First and foremost, avoid overloading the circuits. Second, you should check electrical appliances and wires frequently and use outlets properly. For example, don’t try to force a three prong plug into a two prong outlet or break off the grounding plug in order to make them work in the two prong socket. Finally, replace frayed, cracked, or sparking cords or appliance plugs. If an appliance overheats or shorts, it should be replaced to prevent future problems or even a fire.
Questions of a Do It Yourself nature should be submitted to our
