cancel
Job type :
Zip Code :
community forums
comments
Dummy Door Knob Installation
Installing a dummy door knob is a simple process that adds beauty and functionality to any non-latching door.
Step 1 – Identify the Door
Most dummy knobs are used on double doors or French Doors that only have one functional door, or on double doors that use top latches so that neither door is functional.
They may also be used on doors for a pantry or shelving unit that has no latch on the door.
Identify the door in the home that is in need of a dummy knob.
Step 2 – Attach the Knob
The knob will likely require only two screws to attach to the door. They are simple to use and install. If you are using a hollow core door, dummy knobs may work loose eventually, since they are attached only to thin, exterior shell of the door.
Step 3 – Test the Knob
See if the knob is solidly attached so that you are able to open and close the door without damaging the door or the knob. If there is a problem, you may need to use a different type of a knob.
member comments
Related Articles
Door Replacement Made Easy
Door Replacement projects are an easy way to transform the look and feel of your... read more
Different Types of Door Locks
This article highlights the uses of 10 different kinds of door locks... read more
How a Door Lock on a Doorknob Works
For security purposes, most doors are equipped with one of two types of door lock... read more
articles we like
Type 2 Diabetes
Type 2 diabetes commonly affects people between the age of forty and forty five. The... read more
Splash Block
A splash block is a small block usually manufactured using concrete which is shaped in... read more
Can't keep up with younger guys? Boost your energyCan't keep up with younger guys? Boost your energy
Increase your energy levels and you can recover faster from your weekend endeavors... read more
sponsored articles of the day
diy centers
