cancel
Job type :
Zip Code :
community forums
comments
Drywall a Ceiling: Tricks of the Trade
Hanging a drywall ceiling is not a one person job, however, should you decide that a drywall ceiling is what you plan to install, take these tips into account.
Have the Right Tools
Make sure you have the right tools for the job – this is true with any job but particularly when working on a ceiling structure. One of the most crucial tools is a “drywall T Square” available at any building supply or hardware stores. This tool will help ensure straight cuts.
Attaching Your Drywall
Use drywall nails and a hammer to attach the drywall to wood studs, or a screw gun. Be sure to set the screws deep enough or else the screws won’t be able to be covered with mud. If they are set too deep, you may rip the paper covering of the sheetrock preventing a smooth finish.
Cutting the Sheet Rock
Always, measure twice and cut once. Put the T Square on the mark where it needs to be cut and use a razor knife to cut the entire square. At the very least, you will need to score the paper well. Hang starting from one side and going all the way across. Any rough edges on the sheet rock can always be trimmed later. Use care when cutting for ceiling fixtures – never force fit a fixture, but if needed, you can always cut a little bit bigger of a space.
member comments
Related Articles
The Pros and Cons of Ceiling SpeakersThe Pros and Cons of Ceiling Speakers
This article discusses the pros and cons of installing ceiling speakers in your home. If... read more
How to Drywall Attics - Safety and PreparationHow to Drywall Attics - Safety and Preparation
This attic section shows you how to drywall when refinishing your attic... read more
How to Drywall in an Attic - Applying and Repairing
articles we like
Many Options For Bay Window Curtains
Bay window curtains give privacy to bay windows, which are often the focal point of... read more
Customize Your Window Treatments
Custom window treatments let you coordinate the style, pattern and color of your window treatments... read more
Time to Finally Get That Degree?Time to Finally Get That Degree?
Online degree programs have led to happier, more rewarding and lucrative careers for millions of... read more
sponsored articles of the day
diy centers
