cancel
Job type :
Zip Code :
community forums
comments
Dry Foam Carpet Cleaning: How it Works
Dry foam carpet cleaning is a good way to clean your carpets with minimal moisture. Many people are switching to this method because it is effective and dries quickly.
Dry Foam Basics
In order to take advantage of dry foam carpet cleaners, you will need a carpet cleaning machine to lay down the foam. The machine is required because, in addition to the application of the foam, you the bristles from the machine to agitate the carpet and break loose any dirt or stains.
Most machines are also designed to vacuum up the leftover residue, if any, directly after the application. If the machine does not have a vacuum built in, simply wait until the carpet dries and go over it with a regular upright vacuum to remove any leftover residue.
Getting Started with Dry Foam
Before you start cleaning with a dry foam, you need to first vacuum the whole area you will be cleaning. This is important because it eliminates any unnecessary waste of dry foam chemicals. This will also allow the entire dry foam application to get down deep into the carpet fibers and pull out the dirt.
You can find dry foam carpet cleaning products online or at your local general merchandise store as well as specialty vacuum shops.
member comments
Related Articles
Biological Pollutants in Your Home
How to prevent biological pollutants in your home... read more
6 Rug and Carpet Pet Odor Cleaning Steps
Owning a rug carpet and pets almost automatically means dealing with pet odors and stains... read more
Weatherizing 7 - WeatherstrippingWeatherizing 7 - Weatherstripping
This weatherizing section provides weatherstripping information to reduce energy leaks in your home... read more
articles we like
Microlam
Microlam, also known as Laminated Veneer Lumber (LVL) or Lambeam, is a fairly new improvement... read more
Why is Christmas celebrated on December 25?
This article has creative christmas decorations you can make using Christmas tree balls... read more
New energy booster combines quercetin and vitaminsNew energy booster combines quercetin and vitamins
Busy lifestyles make many people search for an energy boost from energy drinks, coffee or... read more
sponsored articles of the day
diy centers
