cancel
Job type :
Zip Code :
community forums
comments
Dining Room Light Fixtures: Types and Features
There are many different types of dining room light fixtures, each with unique features.
Recessed Lighting Fixtures
Recessed lighting fixtures or recessed can lights produce a relatively low level of light. The main disadvantage of this type of lighting is that it doesn’t produce very bright light. In a dining room, however, this type of dim ambient light is usually desirable.
Sconce Lights
Sconce lights are a unique type of wall light which is designed to create focused illumination. They can be used in a dining room to create a low level of light and to spotlight specific objects or areas in the room that you want to stand out. Sconce lights do protrude from the wall so they should be mounted at around 72 inches from the floor. They also need to match the general décor of the dining room so they don’t stand out.
Chandelier
A chandelier is a sophisticated lighting option. There are many different types of chandeliers, each with a unique design. Most use clear or colored crystal to offset the light and to cast reflections and shadows on the walls, ceiling and floors. Chandeliers are one of the most popular lighting options for dining rooms because they provide a very sophisticated look. Chandeliers can be expensive, and they also tend to be heavy, so they may not be good in areas with frequent storms, like hurricanes or earthquakes.
Hanging Ceiling Lamp
A hanging ceiling lamp is a standard style light that hangs either a metal cord or pole. Styles range from retro to conservative to modern, so it will be easy to find one that closely matches your dining room's décor.
Wall-Mounted Candle Lights
Candle lights are special light fixtures designed to look like candles. Many of these lights can be dimmed to simulate real flames, which can create an intimate atmosphere.
When picking the right type of lighting for your room, consider the current décor of the room and the effect you want to achieve. Most types of lighting should match the color or materials already in the room, though you do not have to worry about this with recessed lighting, which is mounted flush to the ceiling.
member comments
Related Articles
Picking Out the Perfect Light Fixture
This article highlights different kinds of light fixtures and light fixture parts to help you... read more
Answers to Living and Dining Room Design QuestionsAnswers to Living and Dining Room Design Questions
Answers to members' questions about decorating and designing living and dining rooms... read more
Eye of the DesignerEye of the Designer
Learn what to look for in a beautiful interior, from the Sheffield School of Interior... read more
articles we like
Marble Countertops
Marble countertops are made from highly polished hard crystalline rock. Marble is a metamorphic rock... read more
How To Tint Your Own Car Windows
Tinting windows is not as easy as it looks. Even specialists find the process of... read more
Beach Body BasicsBeach Body Basics
As the weather starts to heat up, so does the desire to get in shape... read more
sponsored articles of the day
diy centers
