cancel
Job type :
Zip Code :
community forums
comments
Designing a Kitchen Using Available Space
by Alden Smith
Many young couples when first starting out cannot afford to knock out walls or do a new build to renovate a kitchen badly in need of refurbishing. Budget constraints can often hamper the simplest projects. Whatever the circumstances, there are times when you must make do with what is available.
Not every kitchen renovation is as simple as knocking out walls or adding a new room to the house. People are often restrained by the size of their property, or live in a building where a full renovation is not possible. They may live in a downtown apartment, or be constrained by the infrastructure of the building they live in. When this happens, people are often at a loss as to what to do about a dingy, outdated kitchen. The focus of this article will be on renovating a kitchen and using the available space.
Types Of Kitchens
There are as many different types of kitchens as there are homes. Buy a home built by an older couple and you will often see a tiny, efficient kitchen. People with large families often have a larger kitchen. Today, with the advent of the woman who works outside the home, a balance needs to be made between efficiency and convenience. Whatever the circumstance, if you inherit this kitchen, and are not happy with it, then a change needs to be made.
The Different Sizes
You may live in a home with a mini, midsize or full kitchen. Each of these can be designed to help you build a kitchen you can be happy with. Let's look at each.
  1. The mini kitchen is perfect for a couple without
    children or a career person. You can do a lot with a
    kitchen this size. On the market today are many highly
    efficient and compact appliances that fit the needs
    of this population. These also have the advantage of
    being very energy efficient.
  2. If you cannot open the kitchen up by moving a wall or
    replacing a closet, consider adding a skylight to give
    the visual effect of more space. You can enlarge
    existing windows or even break through an interior
    wall to expand.
  3. A mid-sized kitchen offers convenience and a gathering
    place for the family. Many homes have these. To make
    the best use of space, try opening up the kitchen to an
    adjoining room. You should make long countertops that
    are not broken up by appliances. Place these at the
    ends. Consider a cooking island to increase countertop
    space and food prep area. Keep colors and patterns light
    to maximize visual space. If the kitchen opens into an
    adjoining room, try to match the décor to give the effect
    of greater area.
  4. Today, a trend in newer homes is towards a larger
    kitchen, where family can gather and a couple shares
    cooking duties. These kitchens are often used for
    entertaining, where several couples can join in and
    create meals. The good thing about kitchens of this
    size is that two sinks or ranges can be installed
    along with an island for either food prep or stove
    top cooking. A snack bar or breakfast nook fits in
    well here. There is also the opportunity for more
    design and decorating features in a kitchen of this size.
What To Consider
A project of this magnitude is almost always constrained by budget. You can really spruce up a kitchen with refinishing older cabinetry and adding new flooring. Cork floors are very nice in a kitchen, and the key word for them is durability. There are cork floors in use today that were installed in 1890.
Terracotta and porcelain tiles work well in a kitchen, and taking a little extra effort in choosing color and pattern can quickly change how the kitchen looks. Designers will lay out these floors with a natural lead in to other rooms, and the size of the kitchen will seem to be increased.
The use of appropriate colors in decorating can also go a long way in making a kitchen seem larger than it really is. Using open shelving and displaying colorful plates or teapots brings space into a room. The utilization of carefully planned cabinetry helps a lot here. Try installing rollouts that the cupboard door is attached to for space saving ideas. Install things such as microwaves, spice racks and can openers under the cabinets to increase counter space.
Don't despair if you have a small kitchen and feel you need more room. On the market today are kitchen plans, such as Scavolini that combines both efficiency and space saving dimensions to any kitchen. Use your creativity and imagination to get the kind of kitchen you wish, regardless of its size.
Alden Smith is an award winning author and regular contributor to DoItYourself.com. He writes on a variety of subjects, and excels in research.
member comments
Related Articles
Elements of an Energy Efficient HouseElements of an Energy Efficient House
Elements of an energy-efficient house... read more
Kitchen Trash CansKitchen Trash Cans
Kitchen Trash Cans are, believe it or not, an important aspect in kitchen decorating... read more
Designs For Kitchen Cabinets
Kitchen cabinets are the most important design element for your kitchen... read more
articles we like
Cleaning Granite Countertops
Cleaning granite countertops can be done quickly and affordably. The most important thing to do... read more
Making Over the Porch for Greater Curb Appeal
Making over the porch successfully can be done to suit a variety of budgets as... read more
Moms Can Earn Online Degrees to Help with Family's Economic WorriesMoms Can Earn Online Degrees to Help with Family's Economic Worries
A growing number of working mothers are studying online to improve their careers. These busy... read more
sponsored articles of the day
diy centers
