cancel
Job type :
Zip Code :
community forums
comments
Decorate With a Copper Shower Faucet
Copper shower faucets have recently come back into style as a modern take on a traditional finish. Copper was replaced largely by brushed nickel during the past few decades. If your bathroom has travertine tile or earth tones, though, copper can come to life and be nice decorative element. Changing out your shower faucet is not hard. Skip on the plumber and do it yourself.
Simple to Do
Since you are replacing a faucet and not installing a new one, it is likely a lot of the basics have been taken care of. Start by removing the existing faucet. You should be able to do this with a simple screwdriver. You can remove any caulking with a knife. You should see a shut off valve for the hot and cold water; shut these off using a flat head screwdriver.
Remove the old faucet and cartridge. To place the handle, slide it into the valve. Using a hexagonal key, place the handle screw adapter in the cartridge. The show head can be screwed in manually using a wrench. The spout can be installed by turning it on the pipe so the screw faces up. Tighten the screw with the hexagonal key then flip the spout.
Finally, turn the hot and cold water supply to check for leaks. You now have a decorative copper shower faucet.
member comments
Related Articles
Protecting Your Pipes
Protecting Your Pipes... read more
Home Water Treatment Information
Finding the right water treatement without the pressures of a salesperson... read more
More Home Water Treatment Information
How and Why To Buy A Home Water Treatment Unit including how tos, FAQ's and... read more
articles we like
Why is Christmas celebrated on December 25?
This article has creative christmas decorations you can make using Christmas tree balls... read more
Creating Your Own Bay Window Treatments
Bay window treatments finish the look of a bay window. There are many options for... read more
Get a $1,500 credit for buying new windowsGet a $1,500 credit for buying new windows
You may be suffering from drafty windows, which over the years have settled, shifted or... read more
sponsored articles of the day
diy centers
