cancel
Job type :
Zip Code :
community forums
comments
Deck Floor Sanding Step-By-Step
Sanding a deck floor is an important step to keep your deck in great shape. A deck should be sanded down and refinished every 3 to 5 years. This will allow a stain or sealant to penetrate the wood farther, helping it to stand-up to the elements more effectively.
Tools and Materials Needed:
  • Sandpaper brick or orbital sander
  • Sandpaper (coarse and fine)
  • Mop
  • Cleaning chemicals
  • Shop vacuum, broom or other device which can be used to clean dust
Step 1-Clean Your Deck
Clean your deck thoroughly by removing all objects from the deck. Vacuum then use a mop and cleaning chemicals to wash it. Allow the deck to dry completely after mopping.
Step 2 – Prepare Your Sanding Tool
Install coarse grade sandpaper on an orbital sander or a sand brick.
Step 3 – Sanding With Coarse Grade Sand Paper
Use your sand brick or orbital sander to sand a portion of the deck using the coarse grade sandpaper. This will remove the existing finish from the deck and a thin top layer of wood. Use a back and forth movement. Remember, if you are using an electric sander, you must always keep it moving or you could easily over sand a spot.
Step 4 – Sanding With Medium Grade Sand Paper
Switch to a medium grade sandpaper and completely sand the section. This will help to smooth out the deck and remove rough areas.
Step 5 – Sanding With Fine Grade Sand Paper
Using your fine grade of sandpaper and your orbital sander or sand brick, sand the deck down one last time. This will create the final smooth finish which is comfortable to walk on and ready for staining.
Step 6 – Clean Dust
Clean any dust which has accumulated on other parts of the deck which have not yet been sanded.
Step 7 – Repeat Process
Repeat steps 3 through 6 for each section of your deck. Remember, you should always clean the dust off before moving to another section. This will reduce wear on the sandpaper.
Step 8 – Clean Up
Using a vacuum or broom remove all dust and any other debris which has accumulated on the deck before applying a stain or sealant.
member comments
Related Articles
How to Design a Deck
Stept by step instructions to designing and planning the deck of your dreams... read more
Factors to Consider Before Building a Deck
Before you begin building your deck, let this article helps you carefully consider the reasons... read more
Answers to Deck Questions #1
Answers to members' questions about deck building and maintenance... read more
articles we like
Outdoor Chair
An outdoor chair can be a variety of chairs used in outdoor settings which have... read more
Tempered Glass
Tempered glass is also called toughened glass. Tempered glass has been processed by intense heating... read more
When Styles Collide: Five Tips for Merging His and HersWhen Styles Collide: Five Tips for Merging His and Hers
Couples spend months planning every detail of their wedding day, but what about the planning... read more
sponsored articles of the day
diy centers
