cancel
Job type :
Zip Code :
community forums
comments
Cordless Screw Driver
A cordless screw driver is a battery powered screw driver. It works just like an electric screw driver. Powered cordless screw drivers also give you the option of reverse or forward. When using a cordless screw driver you get more pressure than a regular screw driver. A cordless screw driver is more convenient than a regular screw driver.
When building something that needs support (such as a deck) you would want to use a cordless screw driver. They have a lot more power and get the job done a lot faster. A cordless screw driver would be a perfect tool to use when hanging drywall.
Inside of a Cordless Screw Driver
Some things that you might find when looking on the inside of a cordless screw driver would be things such as:
  • A switch
  • A rechargeable battery
  • A dual planetary gear system
  • An electric motor
  • A chuck which holds the screwdriver in place
member comments
Related Articles
Build Your Own Kitchen Pantry Storage Cabinet
Unless you have custom cabinets, often times kitchen cabinets are either too deep or too... read more
Selecting the Right Screwdriver for the Job
This article discusses the characteristics and purposes of 14 different screwdrivers... read more
Phillips Screw Driver
Almost anything that needs assembly will call for a Phillips screw driver. You can be... read more
articles we like
Why is Christmas celebrated on December 25?
This article has creative christmas decorations you can make using Christmas tree balls... read more
Ribbon
In construction terms a ribbon refers to a board or lengths of board which are... read more
What Drives NASCAR's John Roberts?What Drives NASCAR's John Roberts?
Millions of viewers know John Roberts as the co-host of SPEED's "NASCAR RaceDay," traveling from... read more
sponsored articles of the day
diy centers
