With the increasing cost of utilities, many homeowners have turned to alternative forms of energy to power their houses, including solar electricity. This method of providing electric power balances the inconveniences of installing a new electrical system with the enormous long-term benefits that come with converting to solar. This article will show what it takes to use solar electricity to power your way down to a near-zero-dollar utility bill.
Where the Power Comes From
The best way to start this project is to understand where the electricity comes from and how it is generated. Solar electricity is generated from photo-voltaic panels which can be placed in any southern-facing direction to capture energy from the sun. The word photo, meaning "light" and voltaic, referring to generation of electricity, mirror the simplicity of this process. The main way that photo-voltaic panels, or PV panels, work is by generating a current of electricity between a positively charged panel and one that is negatively charged. This electricity is then channelled to your home.
First Steps and Installation
The first step to becoming solar-powered is to install the PV panels. The most efficient way to do this is to install them on southern-facing portions of your roof. This will ensure maximum exposure to the sun. Recently, an innovation has been made that allows for PV tiles to be applied directly to roofs in order to generate solar electricity. This accomplishes two things: easier installation and improved appearance. Installing these PV tiles is easier than ever since the pieces fit together like Lego blocks or pieces of a puzzle and is the ultimate solution for this do-it-yourself project.
Potential Home Modifications
You will also need to modify certain aspects of your home to retain the maximum benefits from this system. Most importantly, you will need to install a power inverter. The reason for this is that the energy generated from the PV panels is in the form of a direct current. To be able to use this energy, you need to transform this into an alternating current with the help of an easy-to-use inverter. As well, if it is possible, you should try moving your air conditioning vents to the center of the rooms in your house, which allows for easier distribution of energy and takes less electricity to keep them functioning properly. Along with PV tiles, you will need to install a separate power meter which will gauge the amount of energy generated from your solar tiles.
To conclude, solar electricity is the way of the future in terms of helping the environment and helping yourself escape from expensive utility bills. Also, if you manage to produce more energy than you use in a given month, you can even sell it back to the local energy companies.
Questions of a Do It Yourself nature should be submitted to our
