cancel
Job type :
Zip Code :
community forums
comments
How to Repair Damaged Carpet
By Murray Anderson
With the price of carpet these days, we all want to make sure that the carpet in our homes lasts. That's why one of the most disheartening things that can happen is to get a stain or a burn on your carpet. However, just because your carpet has had an accident doesn't mean you need to replace it. You may be able to patch the damaged section.
Minor Damage
Repairing a minor burn or stain may be as simple as trimming the ends of the damaged carpet fibers. Using a sharp pair of scissors (like manicure scissors) or even a nail clipper, carefully trim the stained ends. Don't cut too much or too deep or your carpet will look like it had a bad haircut.
If the mark is deeper, you might need to borrow some carpet fibers. Remove the damaged fibers all the way down to the to the carpet backing, then cut some replacement carpet fibers from an out-of-the-way area, like in the back of a closet. Using a tooth pick, work carefully and slowly and put a drop of a clear waterproof adhesive on the base of each fiber, then attach it to the carpet backing. This process is slow and demanding - you don't want to get glue on any other fibers or you'll end up with a bunch of glued together carpet lumps - but it can save your carpet.
If your carpet has just been crushed under the weight of furniture, you can probably bring it back to life with a spray bottle of water and a hair dryer. Simply dampen (don't soak) the crushed fibers, and while drying them with the hair dryer, brush them up with your hand.
More Major Damage
If you have a stain that is deep into the fibers or covers a larger area, you're going to need to replace the damaged section. Hopefully you still have some remnants of carpet that you saved when it was originally installed, but if you don't, you can still get a replacement section from the back of that closet.
Remember, all carpet has a grain or texture as a result of the way it's manufactured. Brush it one way the fibers stand up, and brush it the other the fibers seem to lay down. You want to make sure that any replacement piece you use is positioned so the grain is running the same way as the rest of the carpet. Also, experts suggest that replacement pieces are less noticeable if they are cut in the shape of a triangle or a circle. Squares and rectangles somehow catch the eye.
Cutting your replacement piece
When it comes to actually cutting out the stained section, you have a couple of choices. You might use the lid from a can as a template. Nail the lid to the floor and using a sharp utility knife, cut around the edges of the lid. Use the same lid as a template to cut your replacement piece, and you will have a very close match.
A more accurate method is to lay your replacement piece right over the stained area (be sure the grain is running the right way), and then cut through both layers of carpet at the same time. This way, your replacement piece will exactly match the shape of the damaged section you're taking out.
Fastening the replacement piece
Double-sided carpet tape is the easiest method for fastening the patch in place. Stick the tape on the floor first, making sure it gets right to the edge of the hole, then peel the top section of the tape and put the patch into the hole. Carpet tape will hold the patch, but over time, it will dry and lose it stickiness. Plus, it won't stand up well to any moisture from cleaning your carpets.
An alternative method to fasten your patch is to use clear waterproof adhesive or clear silicon caulk. Either of these will stand up better over time and they won't be damaged by carpet cleaning liquids. Put the adhesive around the edges of the patch and press it into the hole. Here again, be sure you don't get any on the undamaged carpet fibers.
Brush the carpet fibers of the patch and the undamaged carpet together with your hand to remove the visible line where the patch meets the carpet. Put some weight on the patch (books make a good choice) and leave it for 24 hours.
A couple of points
When you cut out the damaged piece of carpet, save the piece of underlay that comes out. You will need to put it back into the hole to make sure the height of the patch is the same as the original carpet. If the underlay itself was damaged, you can use a piece of material like burlap as a substitute.
The shorter the pile of the carpet, the harder it is to make a patch invisible. Unfortunately, patching a carpet is unlikely to make it look as good as it did originally, but it will still look a lot better than a big stain or burn.
Murray Anderson is an experienced freelance writer with articles published in both the United States and Canada. He has written on a wide range of topics, but specializes in home maintenance and how to's.
© 2006 DoItYourself.com
member comments
posted Sep 26, 2009
I tried to repair a burn in my carpet, following the above methods. But it looked terrible and after a few weeks it started to unravel.
I live in Melbourne and found Rick Cappell, the
Carpet Repair Specialist.
He did a great job. the Carpet repair was invisible.
Go to his website and check him out. Have a look at his
testimonals page.
www.carpetrepairspecialist.com.au
Related Articles
Carpet Care: What You Should Know
By practicing some basic carpet care maintenance and prevention, you can keep your carpet looking... read more
How to Install Carpet
A step-by-step guide to installing new wall to wall carpet, including removal of the old... read more
Cleaning Berber Carpet with Homemade Solutions
Understanding how Berber carpets differ from the more traditional pile carpets in many homes will... read more
articles we like
Granite Countertop Colors
Black is the most common granite countertop color. This has led to the perception that... read more
Customize Your Window Treatments
Custom window treatments let you coordinate the style, pattern and color of your window treatments... read more
Bad Credit, Poor Economy: You Can Still Get a Auto LoanBad Credit, Poor Economy: You Can Still Get a Auto Loan
Getting tired of sinking money into that old jalopy in the driveway? If your car... read more
sponsored articles of the day
diy centers
