cancel
Job type :
Zip Code :
community forums
comments
Advantages of a Vent-Free Fireplace Insert
Adding a vent-free fireplace insert can add a lot more than just beauty to a fireplace. Here are a few of the benefits.
Efficiency
Adding a fireplace insert can actually increase the efficiency of your fireplace. Since an insert is like adding another fire to your fire, the big fire won’t have to draw as much heat to aid in combustion. This means your room will stay warmer for a longer period.
Clean
A fireplace insert is completely clean. It doesn’t waste energy, and it doesn’t add any toxins in to the air.
Never Be Without Heat
Even if the power is out, you’ll be able to use the insert to generate heat.
Cost
While the upfront cost may scare some people away, it’s important to remember the savings over time. A standard fireplace is a pretty inefficient appliance. They are great to look at, and they will heat a room. But you loose a lot of heat. Adding an insert helps combat heat loss. An insert can potentially save you thousands over the course of a few years.
member comments
Related Articles
Integrated Wood Energy Systems for Sustainable Housing
This paper discusses environmentally sustainable housing principles and illustrates their application with three built projects... read more
Heating Wood Stoves
Heating wood stoves provide an alternative to fireplaces and other heating options. Similar in design... read more
Wood Pellet Stoves: Tips and Tricks
Wood pellet stoves are stoves that burn compressed wood for heating residential spaces. Wood pellets... read more
articles we like
Screed
A screed is a flat, straight tool used for the purpose of leveling and smoothing... read more
Structural Timbers
Structural timbers are wood pieces larger than 4X6, used in framing and structural construction. Structural... read more
How to Reduce the Stress of Business TravelHow to Reduce the Stress of Business Travel
There's a reason frequent business travelers have earned the nickname "road warriors." Business travel can... read more
sponsored articles of the day
diy centers
