cancel
Job type :
Zip Code :
community forums
comments
About Exterior Siding
The kind of exterior siding you choose for your house will depend on cost, decorative style and ease of maintenance. There are a number of outside sidings to choose from, and most can be fixed to insulation boards for maximum energy saving.
Wooden Clapboard
This gives a traditional effect, and is usually made from a durable hardwood like cedar or redwood. Wooden clapboard is straightforward but time consuming to install, and high maintenance, as it needs to be painted or stained.
Stucco Siding
Stucco is a mixture of cement, water and sand or lime. You can either apply it to prepared masonry or chicken wire. Alternatively, you can purchase synthetic stucco in panels which is made of foam insulation. However, while this is easy to install, it is porous and can become damaged by water.
Vinyl Siding
Vinyl siding is made of polyvinylchloride (PVC), which is probably the easiest exterior siding to install as it comes in sheets which can be fixed to the existing structure. It is cheap and requires little to no maintenance. However, it can crack and is arguably harmful to the environment because it is derived from fossil fuels.
Aluminium Siding
Aluminium siding has the advantage of being easy to install and maintenance free. Its cost is comparable to vinyl, although metal siding is not as popular as it used to be, as it can present difficulties with insulation if it is not properly fitted.
member comments
Related Articles
A Guide to Siding TypesA Guide to Siding Types
Learn aboout the many options for siding materials... read more
Selecting Siding for your HomeSelecting Siding for your Home
How to approach the difficult task of choosing new siding for your home... read more
Fiber Cement Siding
Fiber cement siding is durable, safe and green... read more
articles we like
Painting Countertops
Painting countertops has become a popular alternative to replacing laminate countertops, so let’s look at... read more
Comprehensive Health Care
Comprehensive health care in the United States is among the best in the world. There... read more
Feel like screaming at your slow computer?Feel like screaming at your slow computer?
When you start up your computer, does it feel like ages before you can use... read more
sponsored articles of the day
diy centers
