cancel
Job type :
Zip Code :
community forums
comments
About Chainsaw Fuel Mixture
Unlike fuel for your car or lawnmower, chainsaw fuel needs to be mixed before it can be used. Thankfully mixing chainsaw fuel is easy to do once you know what needs to be added to make the fuel mixture
Why a Fuel Mixture?
Because chainsaws use a 2-stroke engine rather than a 4-stroke engine like most automobiles, a special fuel mixture is needed in order to lubricate the moving parts of the chainsaw engine.
What Is in Chainsaw Fuel Mixture?
Oil is added to the gasoline in order to lubricate the moving parts of the engine. There is a certain ratio needed to the chainsaw mixture for it to work. While the most common ratio in the United States is 50:1 gas to oil, this can vary depending on the make and model of your chainsaw. To be 100% sure of the ratio, check your owner's manual or check with the manufacturer.  It’s important to get the ratio right so that your chainsaw continues to work and the engine doesn’t seize up.
Replacing Your Chainsaw Fuel Line
Sometimes your fuel line can break or become cracked and it will need to be replaced. This is something that you can easily do yourself by removing the broken line and then threading the new line back in.
member comments
Related Articles
Garden Green with Cordless Electric Gardening ToolsGarden Green with Cordless Electric Gardening Tools
When it comes to working in and around the yard or garden, we’ve become used... read more
Gardening Tools for the Beginning Gardener
A basic list of common gardening tools for the beginning gardener... read more
Must Have Tools for the GardenMust Have Tools for the Garden
Along with the arrival of spring comes thoughts about spring gardening. Working in a garden... read more
articles we like
Structural Timbers
Structural timbers are wood pieces larger than 4X6, used in framing and structural construction. Structural... read more
Site Work
Site work is a term used to describe any work done when preparing a site... read more
Confused by all the Mortgage Options? Here's HelpConfused by all the Mortgage Options? Here's Help
Fixed rate. Adjustable rate. Interest Only. Flex. All of the different types of home loans... read more
sponsored articles of the day
diy centers
