cancel
Job type :
Zip Code :
community forums
comments
3 Signs Door Frame Replacement is Necessary
While it may not be necessary each time you change a door, door frame replacement is sometimes a necessity . If you are trying to decide whether you should replace a door frame, here are some things you should be aware of:
The Door Binds
If your door catches or binds on the frame, it is possible that you need a door frame replacement. However, you should try these repairs first:
First, try shimming the top hinge if the binding is near the bottom of the door or shimming the bottom hinge if the binding is near the top.
Second, sometimes binding is caused by a buildup of paint, which can be fixed by sanding the paint down.
However, if these repairs do not work, you’ll likely need to replace the door frame.
Age, Corrosion, or Style
If the exterior of the door frame is dated, damaged or unattractive, then replacing the door frame is a good idea.
You will be able to update the look of the home and remove damaged pieces at the same time, and perhaps even help with any squaring or corrosion problems .
You’re Replacing the Door
Although you may be replacing the door with the same size and style, it is a good idea to replace a door frame if you replace the main door.
The old frame has likely shifted during its use, and it is best to start fresh with a new door and frame at the same time.
member comments
Related Articles
How to Frame a Door
Step by step instructions for building a door frame, hanging the door, and adding a... read more
Weatherizing 7 - WeatherstrippingWeatherizing 7 - Weatherstripping
This weatherizing section provides weatherstripping information to reduce energy leaks in your home... read more
Sliding Patio Doors in Place of French Patio Doors
Some people prefer sliding patio doors to French patio doors because they take up less... read more
articles we like
Cleaning Granite Countertops
Cleaning granite countertops can be done quickly and affordably. The most important thing to do... read more
Casement Windows
Defined as a window that is connected to its frame by a series of hinges,... read more
The Comforts of Home and the Fun of OrlandoThe Comforts of Home and the Fun of Orlando
Visitors to Orlando, Florida, enjoy warm weather, elaborate theme parks, lush golf courses and a... read more
sponsored articles of the day
diy centers
