Bathroom floor plans are essential to follow and adhere to when remodeling or making additions. If you plan on remodeling your bathroom, be sure to remember and take into consideration the following elements that are fundamental to a good floor plan.
Scale
All floor plans are designed to be on a scale. The plan should describe as to what the scale is, which means it should use a particular measurement of distance. This is important when looking over the plan because it will show you every aspect of the bathroom in its length, width, and perhaps height. This allows to see where you can make changes and how those changes will affect the dimensions for the rest of the bathroom.
Doorways and Windows
A common issue with a bathroom floor plan is how a sink or counter can obstruct a doorway. Be sure to check the plan carefully to ensure the spacing shown will allow enough room for the door to fully open. Additionally, window placement is important to consider. If you have an existing window, you'll want to work around it and incorporate your new additions with it in mind. Should you overlook the existing window, you may place something near the window and ruin the function of the bathroom.
Cabinet Space
When looking at the plan, make sure that there is adequate space to open and close your cabinets. This aspect is often overlooked and can present storage problems for your bathroom. With cabinet space included, you'll be able to make other additions without having to worry whether the cabinets will get in the way.
Questions of a Do It Yourself nature should be submitted to our
