Before
After |
We were adding to the side of the house and luckly there was no utilities on this side of the house. We removed all the siding from the side and set it aside for later use. We also had to remove the fence (before photo taken when first moved in before fence was added) so the cement truck could make it back.
After several calls we found a local cement company that would pour the foundation at a reasonable cost. They did the site prep work and poured the 24' X 24' slab.
Over the next two month my wife and I did all the framing, roofing and installed the windows.
I took a piece of the siding taken down earlier to several siding companies until I found a match. We only needed to purchase enough to do the front of the addition. Since the addition fit under the roofline of the existing house and was 4 feet narrower, the siding that was taken down earlier was enough to cover the end. For the back we took down the siding that was on the front and used it for the back of the addition. We then put a faux brick siding on the front.
Due to local building code I was not allowed to do the HVAC and electrical work. To keep cost to a miminun I installed all the outlets, fixtures, and junction boxes. I then pulled four wires from the main circuit breaker box in the garage on the far side of the house to the addition. The electrician then came in and simply made the connections. So that I would not have to deal with gas lines, we added a heat pump unit for the addion. We had two rooms of the exisiting house taken off the existing system added to the new heat pump system to reduce the stain on the existing HVAC system.
In 2008, I hope a long time, waiting for a long time. At one time, many have dreams, hope to achieve in 2008. I hope the total in 2008 to have a good start. But in 2008, when the bell sounded really, I found that everything becomes less important. Ah! The most important thing is what? That is, health, money can buy many things, not only to buy health. Therefore, my dear friends, good to take care of themselves. This article from www.good-handbag.com
